IP network setup DIAL
OK I had a brain fart. What is the most logical way to change static IP on allstar DIAL. Is there a script that can be called to do the network setup and change settings? Getting over a cold and am rather brainless. The Server/node will be going to a different location to be used but setting up here so it will be plug and play for the other location.
Keri
KB0YNA
/usr/local/sbin/netsetup
On 01/23/2016 06:03 PM, Tower DIVA
wrote:
      OK I had a brain fart.�� What is the most logical way to
change static IP on allstar DIAL.�� Is there a script that can
be called to do the network setup and change settings?�
Getting over a cold and am rather brainless.� The Server/node
Keri
KB0YNA
-- "It just works"
