IP doesn't match error
Setting up a node, and from what I can tell he uses T-Mobile for internet (based on the ip’s).
Allstarlink shows the node connected, however, when he connects to the hub, I see this error in the /var/log/asterisk/messages file: (numbers changed…)
-[2025-01-27 20:36:06.737] WARNING[357270][C-00001491] app_rpt.c: Node 55555 IP 172.59.191.111 does not match link IP 172.59.189.22!!
I found some really old threads about lte providers having 2 client ip’s, depending on the traffic type. Wondering if that is what I"m seeing here.
What I didn’t find in those threads was a fix/workaround.
thx
Some T-Mobile hotspots have issues with ASL3’s HTTP Registration. Check out IAX-based registration for more info.
Tmobile employs a VPN to mask your IP. you might need to go to like DuckDNS or something else to allow it to go thru.
