IP address does not match - Stale DNS entry (Previous thread Closed)
Hi all,
Is the issue with the DNS still happening?
I just migrated a node from another "OS" to ASL3 and it refused to update the new public IP. As soon as I changed from node_lookup_method = both to node_lookup_method = file, it started working.
Edit: Apparently changing node_lookup_method was not the fix. The fix was changing;
;register => 1998:12345@register.allstarlink.org
The node is behind a CGNAT (5G internet connection).
73' Frank - KP4IP
Are you referring to the way some hotspots intercept/direct web (HTTP/HTTPS) traffic and route it differently from IAX traffic?
This issue is described in : IAX-Based Registration
Thanks for pointing me to the documentation.
