Does anyone have current instructions on how to install OpenVPN for the HamVoip version of AllStarLink on a Rpi4? None of the info I have looked at seems to line up with any of the files that need to be changed.
I need for the node to be connected to the network without using port forwarding. I have already installed easy RSA and UFW using PacMan. I am also not for certain if any of this in the correct directory.
I have already set up a free account with OpenVPN.
Please let me know how you progress. I have Watchguard installed and works great with exception that Asterisk no longer registers when the vpn tunnel is up. So very odd.
Have a look at wireguard. Simpler and superior in all regards of a layer-3 only tunneller. Installation is easiest if you have a linux kernel v5.6 or newer. Trickier if older. /S
