Installing Asterisk/Allstar by hand
Hi, it's been a while since I've had my AllStar system running. I'm looking to try and get it back up and running. However, it will be located on a virtual server, and will be basically a conference server. Installing using ACID is not an option, so I will need to configure by hand, except I will be moving my old configuration over to the new box.
I have been meaning to do this for ages, but I had issues installing Asterisk onto my previous VPS, that my provider wasn't able to help with. The new system is Xen based, so hopefully it will compile and install now.
Anyone have any pointers?
73 de VK3JED / VK3IRL
http://vkradio.com
Hi Tony,
The last time I ran asterisk on my Xen based VPS, I installed the asterisk
and asterisk sources packages (ubuntu). Then with that, I re-compiled
asterisk with the app_rpt bits in it. Had no issues with it and it was
easy to maintain.
(Oops, I also installed the libpri and zaptel packages).
As long as you heave the kernel sources available to you, I don't see any
issues compiling it by hand.
Jim, K6JWN
ยทยทยท
to the new box.
install now.
http://vkradio.com
App_rpt-users@qrvc.com
