Install when your Ethernet port is not detected
Hello;
        I had this happen when I was trying to install on my Asus Netbook 900 which has an unsupported ethernet device... I found that the Linksys series USB/ethernet devices are detected in Centos 5.x installs and can be added in long enough to get the install completed then pulled after you locate and find the drivers for for the ethernet adapter.. They are posted by the way.... google if needed.... also the wifi drivers are posted for centos/redhat etc....
Just a little tidbit I ran across in my frustration.. I now keep a Linksys usb/ethernet adapter in my laptop kit for emergencies.. :slight_smile:
Doug
KD8B
At 08:23 AM 9/23/2009, Doug Bade wrote:
yes, but did you set the tidbit, or clear the tidbit? :slight_smile: :slight_smile:
Date: Wed, 23 Sep 2009 08:32:57 -0400
To: app_rpt-users@qrvc.com
Subject: Re: [App_rpt-users] Install when your Ethernet port is not detected
Hello;
Netbook 900 which has an unsupported ethernet device… I found
the ethernet adapter… They are posted by the way… google if
needed… also the wifi drivers are posted for centos/redhat etc…
Just a little tidbit I ran across in my frustration… I now keep a
Linksys usb/ethernet adapter in my laptop kit for emergencies… :slight_smile:
Doug
KD8B
App_rpt-users@qrvc.com
