Install scripts
Hello, I’m looking for install scripts for Debian. I’m using a cloud base VM server and wanted to see if I can in Dial RC1 on it.
Thanks, David
KE6UPI
May want to start here https://github.com/AllStarLink/DIAL
Looks like it provides a script to install onto an existing Debian box.
Jim, K6JWN
________________________________________
From: App_rpt-users <app_rpt-users-bounces@lists.allstarlink.org> on behalf of David KE6UPI <dshaw@ke6upi.com>
Sent: Wednesday, June 7, 2017 4:16 PM
To: APP RPT
Subject: [App_rpt-users] Install scripts
Hello, I'm looking for install scripts for Debian. I'm using a cloud base VM server and wanted to see if I can in Dial RC1 on it.
Thanks, David
KE6UPI
Thanks Jim, I should have known. I wasn’t thinking.
David
Jim, K6JWN
From: App_rpt-users app_rpt-users-bounces@lists.allstarlink.org on behalf of David KE6UPI dshaw@ke6upi.com
To: APP RPT
Thanks, David
KE6UPI
Thanks, David
“Laws that forbid the carrying of arms…disarm only those who are neither inclined nor determined to commit crimes. Such laws make things worse for the assaulted and better for the assailants; they serve rather to encourage than prevent homicides, for an unarmed man may be attacked with greater confidence than an armed one.”
Thomas Jefferson
I was just looking at the install script has anyone tried this with centos 7?
David
Loren Tedford (KC9ZHV)
Phone:
Fax:
Email: lorentedford@gmail.com
Email: KC9ZHV@KC9ZHV.com
http://www.lorentedford.com
http://www.kc9zhv.com
http://forum.kc9zhv.com
http://hub.kc9zhv.com
http://Ltcraft.net
http://voipham.com
Thanks, David
Thomas Jefferson
Jim, K6JWN
To: APP RPT
Thanks, David
KE6UPI
Hey Loren, Looks like Debian. Sorry
David
Thanks, David
Thomas Jefferson
Phone:
Fax:
http://Ltcraft.net
http://voipham.com
David
Thanks, David
Thomas Jefferson
Jim, K6JWN
To: APP RPT
Thanks, David
KE6UPI
at the beginning of the script it is stated that it is for debian.
And line 11 make it obvious.
apt-get install unzip -y
Centos is based on RHEL so it use yum as a package manager, debian based use apt.
It could work on a Ubuntu or other debian derivative but will definitly wont work on a Red Hat derivative.
Thanks, David
Thomas Jefferson
Phone:
Fax:
http://Ltcraft.net
http://voipham.com
David
Thanks, David
Thomas Jefferson
Jim, K6JWN
To: APP RPT
Thanks, David
KE6UPI
So it wouldn’t install on OpenVM. I can’t find the kernel headers. I’ll check with the hosting site… I loaded Debian 7.0 i386…
Thanks, David
David
Thanks, David
Thomas Jefferson
Thanks, David
Thomas Jefferson
Jim, K6JWN
To: APP RPT
Thanks, David
KE6UPI
David actually what i was referring to was going through and finding the packages for yum instead of apt-get… I was considering downsizing one of my nodes out at the data center… That’s why i was asking if anyone has converted this to centos 7 yet… I will try and see if i get enough time to play with it and see if i can find equivalent packages to make allstarlink work in centos 7 but no promises…
Thanks, David
Phone:618-553-0806
Fax: 1-618-551-2755
http://Ltcraft.net
http://voipham.com
Thanks, David
Thomas Jefferson
David
Thanks, David
Thomas Jefferson
Jim, K6JWN
To: APP RPT
Thanks, David
KE6UPI
Hey Loren, I didn’t see to many apt-get(s) in the script folders. A couple of files where apt-get installs. Didn’t look too bad.
David
Thanks, David
Thomas Jefferson
Phone:618-553-0806
Fax: 1-618-551-2755
http://Ltcraft.net
http://voipham.com
Thanks, David
Thanks, David
Thomas Jefferson
David
Thanks, David
Thomas Jefferson
Jim, K6JWN
To: APP RPT
Thanks, David
KE6UPI
Not all hosting site permit the installation of kernel module like Dahdi, si check with then before going further.
Thanks, David
Thomas Jefferson
Phone:618-553-0806
Fax: 1-618-551-2755
http://Ltcraft.net
http://voipham.com
Thanks, David
Thanks, David
Thomas Jefferson
David
Thanks, David
Thomas Jefferson
Jim, K6JWN
To: APP RPT
Thanks, David
KE6UPI
Well then I suppose it’s a good thing that I rent the whole rack server lol… I am my own web email host provider… As far as my idea I have been doing some reading on installing aptitude in Centos… I use Nethserver for my web email and vpn solutions so I am going to start up another vps with neth 6.8 or 7 and see what happens…
Phone: 618-553-0806
Fax: 16185512755
http://kc9zhv.com
David
Thanks, David
Thomas Jefferson
Phone:618-553-0806
Fax: 1-618-551-2755
http://Ltcraft.net
http://voipham.com
Thanks, David
Thanks, David
Thomas Jefferson
David
Thanks, David
Thomas Jefferson
Jim, K6JWN
To: APP RPT
Thanks, David
KE6UPI
Howdy!
The HDD in my asterisk VoIP phone system just took a dive, and I have
begun to explore methods that were sought out by W9SH, and his
allstarlink implementation of XIPAR.
Unfortunately, his project is now known to be defunct, and is on CentOS
6.
Has anyone changed their AllStarLink DIAL system to have some of the
features, such as AJAM?
I used FreePBX in the past, so I am considering different methods of
implementation of re-compiling an older version of FreePBX with matching
Asterisk version used with DIAL with app_rpt and chan_simpleusb, (and
others)
or,
just re-compiling asterisk on the current DIAL machine with other
modules enabled, such as AJAM, and supporting config files.
I am aware that I will have to do some serious editing as both AJAM and
FreePBX modify the standard conf files, as any hand editing must be done
in such files ./custom/IAX.conf, ./custom/extensions.conf, and so on.
~Benjamin, KB9LFZ
I am very happy to see this!!
Thanks to all who made this happen!!
~Benjamin, KB9LFZ
Jim, K6JWN
To: APP RPT
Thanks, David
KE6UPI
Have you seen Allmon? https://github.com/tsawyer/allmon2 It uses the AMI to provide a web interface to common repeater control and linking functions. Perhaps you could add the telephone features you need. Attached screen capture to show what it looks like.
On Fri, Jun 9, 2017 at 8:58 PM, Benjamin Naber Benjamin@project23d.com wrote:
Howdy!
others)
or,
~Benjamin, KB9LFZ
Tim
Tim, et al;
I've seen that, and Supermon. Given Supermon is written with PHP,
knowledge of which I do not possess. Also, no sense in re-inventing the
wheel when a webUI already exists.
Any other experiences on this subject?
~Benjamin, KB9LFZ
On Sat, 2017-06-10 at 06:50 -0700, Tim Sawyer wrote:
Have you seen Allmon? GitHub - tsawyer/allmon2: New and Improved AllStar Monitor and Control Panel It uses the
On Fri, Jun 9, 2017 at 8:58 PM, Benjamin Naber > <Benjamin@project23d.com> wrote:
        Howdy!
        I have
        on CentOS
        6.
        of the
        methods of
        with matching
        others)
        or,
        other
        AJAM and
        must be done
        so on.
        ~Benjamin, KB9LFZ
        email confirmation. If you have trouble unsubscribing, please
        send a message to the list detailing the problem.
Tim
