Ilink,6 command syntax ... via management interface port 5038
Could you help me with the correct syntax for the ilink,6 command via the management interface ?
Connecting a single node with the following command:
Connect:
ACTION: COMMAND\r\nCOMMAND: rpt cmd 48035 ilink 3 52879\r\nActionID:16167\r\n\r\n
... works in ASL3 and HamVoIP
Disconnect all:
ACTION: COMMAND\r\nCOMMAND: rpt cmd 48035 ilink 6 \r\nActionID:13389\r\n\r\n
... works in HamVoIP but errors in ASL3:
Response: Error
ActionID: 13389
Message: Command output follows
Output: Usage: rpt cmd
Output: Send a command to a node.
Output: i.e. rpt cmd 2000 ilink 3 2001
... I've tried with and without the space after the 6.
I don't know if this is a recent change or it's never worked in ASL3, I suspect it's fairly recent ... we only just realized that "disconnect all" was not working. Maybe you tightened up something that we'd historically been "getting away with" ?
Best,
Gerry.
W6WNG
Try ilink 6 *
Don't know why, but that works, where ilink 6 by itself doesn't. Not sure if this is intended.
This will likely be fixed in the "next" release with app_rpt : PR #604.
In the meantime, @N2DYI's suggestion should work.
Bingo !
I should have thought of that - the * makes up the correct parameter count ...
Thanks all ...
Happy Friday !
Gerry.
W6WNG
