I've been looking for a version of this command which will remove all
connected links excluding permalinks.
It doesn't appear there is an easy way to do this in the code, does anyone
have any ideas as how to do it?
73's
73's
Why not run a shell script to disconnect all nodes then reconnect the nodes that you wish to be connected…
Loren Tedford (KC9ZHV)
Email: [email protected]
Phone:
Fax:
http://www.lorentedford.com
http://kc9zhv.com
On Mar 19, 2017 10:36 PM, “Bryan Fields” [email protected] wrote:
I’ve been looking for a version of this command which will remove all
It doesn’t appear there is an easy way to do this in the code, does anyone
73’s
Bryan Fields
727-409-1194 - Voice
Put this under your [functions] stanza. Make xx whatever you want for the disconnect command.
xx=ilink,6 ; disconnect all nodes
Here a list of ilink commands from the app_rpt source
73’s
Bryan Fields
Tim
I think you misunderstood what I was asking.
I'm looking for a command to disconnect all nodes other than permalink nodes.
disconnect command.xx=ilink,6 ; disconnect all nodes
Bryan Fields
http://bryanfields.net
Is that not *71
Bob
k6ecm
Sent from iPad
Bryan Fields727-409-1194 - Voice
[email protected]
http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-usersTo unsubscribe from this list please visit http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
No, it's not.
ilink,6 disconnects all nodes, I'm looking for a way I can have it disconnect
all normal ilink,2/3 linked nodes, but leave the permalinks (ilink,12/13)
connected.
On 3/21/17 12:32 AM, Bob Pyke wrote:
Is that not *71
Bryan Fields
Hi Brian,
There is no current way to disconnect all normal connections while leaving
permanent connection linked, as far as I know (and I've been through that
code a lot).
On the node where the permanent connection is initiated, some code could
be added to accomplish selective disconnects, theoretically
speaking---something like a modified ilink,16 command. The only difference
between permanent and normal connection is the setting of the internal
"max_retries" variable to a huge value (in app_rpt.c, see the name:
MAX_RETRIES_PERM) and the setting of the "perma" variable, which is simply
a flag---so, connections are really permanent, but connect retries go on
for a very long time! ...In app_rpt.c, see the comment:
/* Make a string of disconnected nodes for possible restoration */
In app_rpt, the initiating node is to only place where the"max_retries"
and "perma" variables are visible...From the "target" node's perspective
(i.e.: the node which was connected TO via a permanent connect command),
there is no way to tell any difference, unfortunately, so no way to
perform a selective disconnect without changes to telemetry.
...It would be nice if more comprehensive telemetry info got passed
between nodes, but, that can't happen without potentially breaking all
legacy nodes which haven't upgraded.
73, David KB4FXC
Is that not *71
No, it's not.
connected.
Bryan Fields
[email protected]
Oops, typo, below should read: "so, connections are NOT really permanent,"
Hi Brian,
code a lot).
a flag---so, connections NOT are really permanent, but connect retries go
on for a very long time! ...In app_rpt.c, see the comment:
73, David KB4FXC
Is that not *71
No, it's not.
connected.
Bryan Fields
[email protected]
[email protected]
I just do a macro that does ilink 6 and then the perm links again.
Lu Vencl
On Mar 21, 2017, at 2:16 AM, David McGough <[email protected]> wrote:
Hi Brian,
code a lot).On the node where the permanent connection is initiated, some code could
for a very long time! ...In app_rpt.c, see the comment:/* Make a string of disconnected nodes for possible restoration */
perform a selective disconnect without changes to telemetry....It would be nice if more comprehensive telemetry info got passed
legacy nodes which haven't upgraded.73, David KB4FXC
Is that not *71No, it's not.
connected.
[email protected]
You do not need a password to unsubscribe, you can do it via email confirmation. If you have trouble unsubscribing, please send a message to the list detailing the problem._______________________________________________
[email protected]
If the permalinks are known, that's good, but unfortunately they can change.
Based on David's comments I think the data needed may not be there on all
systems to be able to do it properly.
Bryan Fields
If there is a way to find out what the permalink nodes are you could script something. Maybe one of Kiel’s scripts will help. http://www.qsl.net/k0kn/scripts.html
If the permalinks are known, that’s good, but unfortunately they can change.
Based on David’s comments I think the data needed may not be there on all
Bryan Fields
Tim
