Ideas re: Unable to connect to remote asterisk (does/var/run/asterisk/asterisk.ctl exist?)
Pi stretch, stock allstar install and allmon2. Using asl-menu I get this message. Have tried to create the dir w diff permissions and owners. I use pi not root for main user. Ideas as to how I can solve or what the core issue may be?
Clifford
KK6QMS
IAX2 show registry:
Did you follow these instructionsfrom the readme ?
http://dvswitch.org/files/ASL_Images/Raspberry_Pi/Stretch/ASL_1.01-20180228-armhf-raspbian-stretch-image.readme
Run the following commands after the first time you boot.
sudo apt-mark hold raspberrypi-kernel-headers raspberrypi-kernel
sudo apt-get update
sudo apt-get upgrade -y
sudo reboot
at the # prompt run "asl-menu" to setup your node.
...mike/kb8jnm
issue may be?
Clifford
KK6QMS
IAX2 show registry:
exist?)
I am not sure if I did during first install. I did try it sometime after. Does it require fresh install to be effective?
Clifford
sudo apt-get update
sudo reboot
at the # prompt run “asl-menu” to setup your node.
…mike/kb8jnm
issue may be?
Clifford
KK6QMS
IAX2 show registry:
exist?)
I have seen many strange things when/if you update/upgrade without putting a hold on updating the kernel headers.
Do it first on first boot.
If you have some other 4gb+ SD card, why not try it again fresh
and be sure.
...mike/kb8jnm
Clifford
sudo apt-get update
sudo reboot
...mike/kb8jnm
use
issue may be?
Clifford
KK6QMS
IAX2 show registry:
exist?)
Ok sounds good I will try it and report back, thanks.
Clifford
and be sure.
…mike/kb8jnm
Clifford
sudo apt-get update
sudo reboot
…mike/kb8jnm
use
issue may be?
Clifford
KK6QMS
IAX2 show registry:
exist?)
the “Unsubscribe or edit options button”
Just realized something- I never used the image- I am installing stretch
from latest build and ASL from dvswitch repository using these instructions-
https://wiki.allstarlink.org/wiki/ASL_FAQ
Clifford
Of Mike
-----Original Message-----
From: App_rpt-users <app_rpt-users-bounces@lists.allstarlink.org> On Behalf
Sent: Monday, September 03, 2018 3:37 PM
To: app_rpt-users@lists.allstarlink.org
Subject: Re: [App_rpt-users] Ideas re: Unable to connect to remote asterisk
If you have some other 4gb+ SD card, why not try it again fresh and be sure.
...mike/kb8jnm
Clifford
sudo apt-mark hold raspberrypi-kernel-headers raspberrypi-kernel sudo
apt-get update sudo apt-get upgrade -y sudo reboot
...mike/kb8jnm
owners. I
use
core issue may be?
Clifford
KK6QMS
IAX2 show registry:
exist?)
message to the list detailing the problem.
Quick and easy.
Get the image to sd card,
run first boot as per the readme
sudo apt-get update
sudo reboot
done !
When you have a working ASL Pi,
Pull your SD card and create a back-up image from the SD !
'For now' this is the preferred method. Should be a update coming to fix the upgrade issues with kernel/sound and change this.
...mike/kb8jnm
ASL FAQ - AllStarLink Wiki
Clifford
Of Mike
...mike/kb8jnm
Clifford
...mike/kb8jnm
owners. I
use
core issue may be?
Clifford
KK6QMS
IAX2 show registry:
exist?)
ok new node up and running using the image and headers hold instructions.
Everything works but still no connect from Zoiper and no allmon2 but will
work on those later. iaxrpt software works/connects fine.
Also- I like having a gui- any suggestions? I had it with stock stretch
install. Is there any downside to installing/enabling gui?
Thanks again-
Clifford
KK6QMS
Of Mike
Sent: Tuesday, September 04, 2018 8:10 AM
Quick and easy.
done !
...mike/kb8jnm
stretch from latest build and ASL from dvswitch repository using these
instructions-
Clifford
Behalf Of Mike
sure.
...mike/kb8jnm
Clifford
0 180228-armhf-raspbian-stretch-image.readme
sudo apt-get update sudo apt-get upgrade -y sudo reboot
...mike/kb8jnm
owners. I
use
core issue may be?
Clifford
KK6QMS
IAX2 show registry:
exist?)
Considering you have no more than 1gb ram to play with,
a GUI is not advisable even if possible.
If you did do this, it
If you are using a program like WinSCP to manipulate the files,
IAXRPT to run remotely.
I do have a 3B+ running ASL with a DMR bridge, a recorder node, has Allmon2 installed. So enough room and speed for that stuff.
that would be as far as I would go. leave some ram to play with something else in the future.
I'm sure you will find the issues for the other things.
...mike/kb8jnm
Thanks again-
Clifford
KK6QMS
Of Mike
Quick and easy.
Win32 Disk Imager download | SourceForge.net
done !
...mike/kb8jnm
instructions-
Clifford
Behalf Of Mike
sure.
...mike/kb8jnm
Clifford
...mike/kb8jnm
owners. I
use
core issue may be?
Clifford
KK6QMS
IAX2 show registry:
exist?)
I don’t know if this has changed, but it’s been my understanding that both the GUI and Allstar want to have control of the server, which, if true, would impact the real-time requirements of asterisk.
Bob
k6ecm
Sent from my iPhone
Thanks again-
Clifford
KK6QMS
Of Mike
Quick and easy.
done !
...mike/kb8jnm
instructions-
Clifford
Behalf Of Mike
sure.
...mike/kb8jnm
Clifford
...mike/kb8jnm
owners. I
use
core issue may be?
Clifford
KK6QMS
IAX2 show registry:
exist?)
I ran w GUI and seemed fine. Was convenient to have browser, text editor etc. I will leave it as it is though and improve my command line skills!
Also to install Midnight Commander I had to un-comment a repository, is that ok in light of the kernel header hold etc. Any reason that would not be a good idea?
Clifford
KK6QMS
I’m sure you will find the issues for the other things.
…mike/kb8jnm
Thanks again-
Clifford
KK6QMS
From: App_rpt-users app_rpt-users-bounces@lists.allstarlink.org On Behalf
Of Mike
Quick and easy.
https://sourceforge.net/projects/win32diskimager/
done !
‘For now’ this is the preferred method. Should be a update coming to fix the
…mike/kb8jnm
instructions-
Clifford
Behalf Of Mike
sure.
…mike/kb8jnm
Clifford
…mike/kb8jnm
owners. I
use
core issue may be?
Clifford
KK6QMS
IAX2 show registry:
exist?)
and press the “Unsubscribe or edit options button”
