I have just installed the ACID build today to get my node online on
Echolink and AllStar. I have an issue though where the box that runs
Asterisk is interfacing with an SCOM 7330 controller which handles all
ID'ing. I have looked through the docs and can't seem to find a place
where I can turn off apt_rpt sending a CW ID. Is there any way to turn
this off? Our system is set up to drop PL on ID from the controller so
it's a bit annoying when the Asterisk install sends ID through the
controller.
I believe that's just a matter of setting:
idtime=0
At least that's how I've done it in the past...
- Jeremy, KD0EAV
Matt Brennan wrote:
Good Day,
controller.
Thanks, I'll give that a try. I was going to try that, but I read in
the code something about enforcing a minimum of 600 seconds so I just
assumed it wouldn't work. I guess I'll see.
Two other questions for the group:
1) Is there an easy way to stop it from saying "to node # # # #"
when it announces someone connecting. I have it set to say the
callsign, which is sufficient. I don't need to know my node # every
time someone connects.
2) Anyone had an issue with it saying the wrong callsigns on
EchoLink? KB1PSB connected the other day, and it announced KT0EE. It
has done this with a few different call signs, afaik all of them on
mobile devices.
Matt, NM1B
On Sun, Oct 24, 2010 at 19:32, "Jeremy R. Geeo [KDØEAV]" <kd0eav@clear-sky.net> wrote:
idtime=0
- Jeremy, KD0EAV
Matt Brennan wrote:
Good Day,
controller.
Take a look at app-rpt.c and you will see a list of functions you can
assign to DTMF sequences. There are 3 functions that control EchoLink
announcements. I have my node set to just announce node numbers.
Create a directory named /etc/asterisk/custom and put an rpt.conf file
there with a stanza for your node functions. Add a '(+) right after the stanza
name. Now you can add custom DTMF codes and associate them with any app_rpt
function you want to use, just like in the main rpt.conf file. I have defined
several new codes here and they will be added to your node's function list on
startup. The new codes will be added everytime you restart asterisk.
mobile devices.
It will only announce the callsign of the node that is connectiong, which
may or may not be the callsign of the actual user.
8-Dale
On Tuesday, October 26, 2010 12:05:03 pm Matt Brennan wrote:
On Sun, Oct 24, 2010 at 19:32, "Jeremy R. Geeo [KDØEAV]" > > <kd0eav@clear-sky.net> wrote:
> idtime=0
> 73
> - Jeremy, KD0EAV
> Matt Brennan wrote:
>> Good Day,
>> controller.
>> Thank you,
>> Matt, NM1B
>> _______________________________________________
>> App_rpt-users mailing list
>> App_rpt-users@qrvc.com
>> http://qrvc.com/mailman/listinfo/app_rpt-users
Open your mind, Read, Learn, Think, Apply..
AllStar Node 2392 / EchoLink 541558 / 73, from N7PKT! http://www.hybotics.com - NEW main site
Just because we can, does it follow that we should?
I'll defer on this one; the only other option I'm aware of is the ability to turn off the announcements all-together...
telemdefault=0
mobile devices.
This is very common - and almost makes the announcements pointless - Echolink has an ability to be proxied through various servers around the Internet in an effort to better enable the mobile (iPhone, and presumably Andriod) versions of the software to work on the various carriers networks which don't always (ever?) work when using UDP on their networks. The nature of the proxy is to establish a stateful TCP connection from the mobile device to one of the various proxy servers on the network. That proxy will then initiate the connection to the (your) node; the side effect is that the incoming connection then assumes both the Callsign AND the Echolink node ID of the proxy server (by IP address), not the originating device. Conversely, a mobile Echolink device behind a proxy can not receive an incoming connection.
Actually this *was* very common for me, until I upgraded to the version that
did away with astdb.
In the new version, the half-dozen proxy connects that I have done - using a
couple of different proxy servers - all announced my call correctly - AND -
I was able to get connected as fast as I could work the mouse. No more
waiting 5 minutes.
Ken
27021
W4BRM/R
-----Original Message-----
From: app_rpt-users-bounces@qrvc.com [mailto:app_rpt-users-
bounces@qrvc.com] On Behalf Of "Jeremy R. Geeo [KDØEAV]"
Sent: Tuesday, October 26, 2010 3:38 PM
To: app_rpt-users@qrvc.com
Subject: Re: [App_rpt-users] ID Question
> mobile devices.
Thanks for your response. I have been trying to figure out what you
mean and I must say, unfortunately, I'm at a loss. I have gone through
app_rpt.c and looked through the code and while I understand a great
deal of it I cannot find the DTMF functions you are referencing. As
far as I know I am running the most recent version from SVN. Any
chance there's an example of what you're talking about out there that
I'm missing?
Also, setting eannmode to 0 doesn't work. Setting it to 2 currently
seems broken as it is announcing node numbers instead of call signs.
Matt, NM1B
Jeremy,
1\) Is there an easy way to stop it from saying "to node \# \# \# \#"
Take a look at app\-rpt\.c and you will see a list of functions you can
Create a directory named /etc/asterisk/custom and put an rpt\.conf file
2\) Anyone had an issue with it saying the wrong callsigns on
mobile devices.
8\-Dale
On Sun, Oct 24, 2010 at 19:32, "Jeremy R. Geeo [KDØEAV]" >> >> <kd0eav@clear-sky.net> wrote:
> idtime=0
> 73
> - Jeremy, KD0EAV
> Matt Brennan wrote:
>> Good Day,
>> controller.
>> Thank you,
>> Matt, NM1B
App_rpt-users@qrvc.com http://qrvc.com/mailman/listinfo/app_rpt-users
mean and I must say, unfortunately, I’m at a loss. I have gone through
chance there’s an example of what you’re talking about out there that
I’m missing?
Also, setting eannmode to 0 doesn’t work. Setting it to 2 currently
Jeremy,
Thanks, I’ll give that a try. I was going to try that, but I read in
assumed it wouldn’t work. I guess I’ll see.
callsign, which is sufficient. I don’t need to know my node # every
several new codes here and they will be added to your node’s function list on
mobile devices.
8-Dale
On Sun, Oct 24, 2010 at 19:32, “Jeremy R. Geeo [KDØEAV]” > >> > >> kd0eav@clear-sky.net wrote:
I believe that’s just a matter of setting:
idtime=0
At least that’s how I’ve done it in the past…
Jeremy, KD0EAV
Matt Brennan wrote:
Good Day,
ID’ing. I have looked through the docs and can’t seem to find a place
it’s a bit annoying when the Asterisk install sends ID through the
controller.
Open your mind, Read, Learn, Think, Apply…
