Hi Robert,
Thanks for the info. There were a couple of items in your list that I didn't have. I'll try them tonight and see if it helps..
When I used to mess with my 706mkIIg with Ham Radio Deluxe, the serial/CIV level converter
I used needed to have one of the handshake leads forced on to power the interface. I want to say DTR, but not sure.
If that's the case I also remember seeing a way to set a ttyS to do that. But again, memory fails me as to the command (setserial ?).
My interface uses an external power source, so I'm positive it's not an interface power issue.
I'll be sure and post a 100% working config once I've got it going.
Thanks. 73
Kyle
K0KN
----- Original Message -----
Sent: Thursday, February 16, 2012 8:59 AM
Subject: Re: [App_rpt-users] Icom 706 Remote Base
While I'm not using an 706, but a Syntor X with an XCAT here's the related stuff in my rpt.conf
(gleaned mostly from an archived Tom Sawyer post that I found in a Google search)
Yes, the CIV address is in decimal.
functions = functions-remote
link_functions = functions-remote
memory = memory ; Section to hold memory entries (optional)
remote = xcat ; Radio Command format
; remote=ft897 for Yaesu FT-897 or
; remote=rbi for Doug Hall RBI1
; remote=kenwood for Kenwood mobiles such as the TMG707A
; remote=ic706 for the Icom IC-706
; remote=xcat for Syntor X with XCAT board
civaddr = 32 ; CI-V address in DECIMAL
ioport = /dev/ttyS0 ; Specify port for serial port (optional)
iospeed = 19200 ; COMM port speed
dusbabek = yes ; Not sure what this is but it needs to be there
uthlevel = 0 ; Remote base authentication level
; authlevel = 0 : Anyone can use it
; authlevel = 1 : Requires log in, Waits for Tx key to ask for it
; authlevel = 2 : Requires log in, asks for it automously
;mars = 1 ; set=1 for IC-706 w/MARS mods (optional)
remote_inact_timeout=0 ; Inactivity timer for remote base nodes only (set to 0 to disable).
remote_timeout=5400 ; Session time out for remote base. (set to 0 to disable)
split2m = 600 ; Set the default tx split to 600 KC
[memory]
;Syntax : CC=RRR.RRR,PPP.P,AAAAA
; C=Channel Number
; R=RX Frequency
; P=PL Frequency
; A=Attributes
;Attributes : a=AM b=LSB f=FM u=USB
; l=Low Power m=Medium Power h=High Power
; -=Minus TX Offset s=Simplex +=Plus TX Offset
; t=TX PL on r=RX PL on
init=147.540,123.0,shrt ;Set to this on startup
00=145.510,123.0,sh
01=145.530,123.0,sh
-- Robert A. Poff
Loganville, PA
WB3AWJ - Allstar 27784
Powered by Linux
