Icom 706 Remote base working (somewhat)
Hello,
I've been struggling to find information about the remote base capability of app_rpt. I am positive that app_rpt is able to talk to the radio, but I can't seem to control the radio otherwise.
When I connect to the remote base node (2214), I hear the message "invalid frequency". If the radio is in Memory mode, it will switch to VFO A, but the frequency and mode are not changed.
I have not had much luck even learning the command syntax. I have read that a Remote base node will not respond to DTMF commands, so I have been issuing the DTMF commands to the connected node instead (rpt fun 2211 *717).
Google found some information for me, but this function also doesn't work when issued from connected node 2211:
       Set freq. VFO MMMMM*KKK*O (Mhz digits, Khz digits, Offset)
      enter a freq like 443.675 + as *1443*675*1 (or 2 or 3)
Of course, I realize that the 706 has limitations with it's CI-v command set. PTT and changing power levels, for example, cannot be done via CI-v. I've been using CI-v to auto-tune my Icom rigs for satellite work for years.
I'd really like to get this working, and will post a how-to article on my web site once this is working.
Many thanks for any info. 73
Kyle
K0KN
--- snippet from rpt.conf ---
; Remote Base
authlevel=0
; authlevel=0 Disables all access control
; authlevel=1 Enables access control, and waits for
; key up before prompting for the access code
; authlevel=2 Enables access control, and prompts for the
; access code at the time of connection
;functions=functions-remote
remote=ic706 ; Icom 706 remote base
ioport=/dev/ttyS0 ; serial port for CAT/CI-v data
iospeed=19200 ; COM port speed
dusbabek = yes ; wtf is this? serial port will not work without it
memory=memory
phone_functions=functions-remote
;mars = 0 ; set=1 for IC-706 w/MARS mods (optional)
civaddr=72
; address should be in decimal, not Hex as Icom uses. Icom
; hex 58=decimal 88. hex 48=decimal 72
split2m = 600
split70cm = 5000
duplex=0
remote_inact_timeout=0 ; Specifies the amount of time without keying from the link. Set to 0 to disable
remote_timeout=0 ; Session time out for remote base. Set to 0 to disable.
remote_timeout_warning=
remote_timeout_freq=
[functions-remote]
0=remote,1 ; Retrieve Memory
1=remote,2 ; Set freq. VFO MMMMM*KKK*O (Mhz digits, Khz digits, Offset)
; enter a freq like 443.675 + as *1443*675*1 (or 2 or 3)
2=remote,3 ; Set tx PL tone HHH*D*
3=remote,4 ; Set rx PL tone HHH*D*
40=remote,100 ; Rx PL off
41=remote,101 ; Rx PL on
42=remote,102 ; Tx PL off
43=remote,103 ; Tx PL on
44=remote,104 ; Low Power
45=remote,105 ; Medium Power
46=remote,106 ; High Power
711=remote,107 ; Bump -20
714=remote,108 ; Bump -100
717=remote,109 ; Bump -500
713=remote,110 ; Bump +20
716=remote,111 ; Bump +100
719=remote,112 ; Bump +500
721=remote,113 ; Scan - slow
724=remote,114 ; Scan - quick
727=remote,115 ; Scan - fast
723=remote,116 ; Scan + slow
726=remote,117 ; Scan + quick
729=remote,118 ; Scan + fast
79=remote,119 ; Tune (brief AM transmission for automatic antenna tuner)
51=remote,5 ; Long status query
52=remote,140 ; Short status query
67=remote,210 ; Send a *
69=remote,211 ; Send a #
; 91=remote,99,CALLSIGN,LICENSETAG ; Remote base login.
; Define a different dtmf sequence for each user which is
; authorized to use the remote base to control access to it.
; For examble 9139583=remote,99,WB6NIL,G would grant access to
; the remote base and announce WB6NIL as being logged in.
; Another entry, 9148351=remote,99,WA6ZFT,E would grant access to
; the remote base and announce WA6ZFT as being logged in.
; When the remote base is disconnected from the originating node, the
; user will be logged out. The LICENSETAG parameter can be optionally specified
; to enforce TX band limits.
;98=cop,6 ; Remote base telephone key
[txlimits]
; TX limits allow TX priveleges to be assigned to a particular license class.
; In the example below, voice priveleges are assigned for US ham
; licensees for 40 meters through 10 meters.
; Each line contains a LICENSETAG defined in a user log in command,
; an =, then a set of band limit ranges. Up to 40 ranges per entry may be defined.
T = 28.300-28.500
G = 7.175-7.300,14.225-14.300,18.110-18.168,21.275-21.450,24.930-24.990,28.300-29.700
A = 7.125-7.300,14.175-14.300,18.110-18.168,21.225-21.450,24.930-24.990,28.300-29.700
E = 7.125-7.300,14.150-14.300,18.110-18.168,21.200-21.450,24.930-24.990,28.300-29.700
[memory]
; Memories for remote bases
;Syntax : CC=RRR.RRR,PPP.P,AAAAA
; C=Channel Number
; R=RX Frequency
; P=PL Frequency
; A=Attributes
;Attributes : a=AM b=LSB f=FM u=USB
; l=Low Power m=Medium Power h=High Power
; -=Minus TX Offset s=Simplex +=Plus TX Offset
; t=TX PL on r=RX PL on
init=147.540,000.0,fs ;Set to this on startup
;init=147.540,123.0,shrt ;Set to this on startup
;init=147.540,s,f ;Set to this on startup
;00=145.510,123.0,sh
;01=145.530,123.0,sh
; 00 = 146.580,100.0,m
; 01 = 147.030,103.5,m+t
;02 = 147.240,103.5,m+t
;03 = 147.765,79.7,m-t
;04 = 146.460,100.0,m
;05 = 146.550,100.0,m
[nodes]
2214 = radio@127.0.0.1/2214,NONE,y ; remote base definition
dusbabek = yes is a hack for syntor xcat. You should not have it for other radios. I suggest removing dusbabek.
The symptoms you describe indicate the serial port is not working for whatever reason. Have you scoped the serial port to see if valid data is coming out?
Tim
:wq
On Feb 20, 2012, at 11:58 AM, K&R Yoksh wrote:
Hello,
Kyle
K0KN
; Remote Base
authlevel=0
memory=memory
civaddr=72
split2m = 600
split70cm = 5000
duplex=0
[functions-remote]
[txlimits]
T = 28.300-28.500
[memory]
; C=Channel Number
; R=RX Frequency
; P=PL Frequency
; A=Attributes
[nodes]
ohnosec.org
Kyle,
I’ve been doing my testing on mine by connecting with the IaxRpt client. Have you tried that to see if it responds?
In my initial work, when I couldn’t get it to play, I found a serial tracker (one of those boxes with LEDs for each line) indispensable.
If you’re sending DTMF from another node (call it node 1234), and that node mutes the DTMF before it gets to the remote (1235), wouldn’t you need
to set up functions/macros on the calling node (1234) for remote commands?
Something like this :
[macros]
010 = 41235010# ; set remote to memory 10 (where the remote is node 1235)
Question for others : What’s the “common” way to pass commands to the remote?
Can you call one of the memories defined in your rpt.conf?
Question for others: What is the source of the value that calls for the ‘invalid frequency’ message? Reported from the radio, or a trap in the software?
                                The reason I ask, is my Syntor will go to 162.550 (rx only) just fine, but I hear the error message return.
Is the CI-V address correct? You have 72 which equals 48h. On my 706mkIIg it’s 58h (88 decimal -default). Just asking.
Tim, thanks for the dusabek comment, helps dispel some of the fog. .
Sorry for not being of more help. Strictly OJT here…
Robert A. Poff
Loganville, PA
WB3AWJ - Allstar 27784
Powered by Linux
