iaxrpt
iaxrpt
Making progress on my node. After several false starts I finally got the node connected and am able to connect via iaxrpt from my Android devices if I use my EXTERNAL IP address.
I cannot connect from Android or Windows using my INTERAL IP address. I followed the guide at hamvoip.com and have double checked everything.
The port is open for both UDP and TCP connections. The firewall seems ok.
It has to be something obvious. What did I miss?
Mike
WM4B
Mike,
Still a lot of possibilities of things that may not be right but,
  Just so that you are conducting a 'good test' behind your nat
through wifi,
  put your phone in airplane mode, then turn just the wifi on and
connect.
  You might also want to turn the forwarding to just the UDP 4569
and specify that in your phone connect,
  guessing your using the android iaxrpt....� like this for your
IP…
  192.169.1.101:4569�� < :port especially if not the norm, but
do it anyway.
That’s a few things to investigate anyway,
Let me know if your still having issues.
  Oh... don't forget to get back out of airplane mode / turn
cellular back on when done.
Hate to see ya late for dinner …lol
…mike/kb8jnm
On 6/28/2018 8:00 PM, Mike Besemer
wrote:
iaxrpt
Making progress
on my node.� After several false starts I finally got the node connected and am able to connect via
        The
seems ok.
It has to be something obvious.� What
did I miss?
Mike
WM4B
Did you add your local node address for each node in the rpt,conf [nodes] stanza?
Bob
K6ECM
On Jun 28, 2018, at 6:12 PM, Mike mm@midnighteng.com wrote:
Mike,
through wifi,
connect.
  guessing your using the android iaxrpt....  like this for your
IP…
  192.169.1.101:4569   < :port especially if not the norm, but
do it anyway.
…mike/kb8jnm
wrote:
iaxrpt
Making progress
        The
seems ok.
did I miss?
Mike
WM4B
[http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users)
To unsubscribe from this list please visit [http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users](http://lists.allstarlink.org/cgi-bin/mailman/listinfo/app_rpt-users) and scroll down to the bottom of the page. Enter your email address and press the "Unsubscribe or edit options button"
As a additional late thought,
what is your bind address in iax.conf ?
0.0.0.0 binds all
  but you can add a 'second line' with your " local address:port "
if it is translated differently than bindport/bindaddress through
your NAT.
…mike/kb8jnm
wrote:
iaxrpt
Making progress
        The
seems ok.
did I miss?
Mike
WM4B
