IaxRpt and Wine
Anyone having issues with IaxRpt running under Wine?
Had been running fine on Mint 17 and wine 1.6. but it quit several weeks ago. It does something very strange.
Receive works fine and the first time you press PTT everything is fine, but the next time the PTT lights up red but transmitter does not key and no audio shows on vu meter.
It does the same thing with different nodes.
Found out another guy running Mint has the same problem.
Tried Wine 1.7 but no change.
I have OpenSuse Leap42 running as a VM with Wine 1.7 and it seems to work fine.
Any ideas gurus?
Ed W8VT
It runs fine on ubuntu. I can’t remember the version but it’s the 14 something lts. Wine I got from the app center. Runs slick!
Wish I could offer more, I’m not a linux guru. I will say it was painless to install and just worked without fiddling, which is what I needed.
N1XBM
Apparare Scientor
Paratus Communicare
Allstar Node # 27086, 41540, 41812, 42086
The iaxrpt software has gradually become in accessible with wine some how over the past little bit of time i have had to experiment with it…
Here is what i have done since wine has started having issues…
I went back to windows 7 as my primary os with secondary boot to xubuntu… inside windows i run vitualbox seemless mode with xubuntu so that way i can still enjoy most of my linux fun…
This has solved the issues with wine which were…
Wine would lock my network traffic to iaxrpt and was unable to use firefox or chrome web browser while using iaxrpt…
Iaxrpt would continue to run in the back ground as a zombie process and would have to either kill it using htop or reboot the entire system to break the zombie process…
Other issues i had with xubuntu unrelated was Bluetooth headset issues… This i was the main cause of me throwing away my two years of enjoyment with linux…
Here is what i did learn about running linux and windows in a vm… Iaxrpt doesnt work correctly and notice jitter and other issues… Also Windows seems to not like virtualized environments in general hope this helps.
On Sun, Nov 8, 2015 at 7:01 AM, Ed Wilhelm vacuumtubesforever@gmail.com wrote:
Any ideas gurus?
Ed W8VT
Loren Tedford (KC9ZHV)
Email: lorentedford@gmail.com
Main Line:1-631-686-8878 Option 1 for Loren.
Fax Line 1:1-618-551-2755
Fax Line 2:1-631-686-8892 (New Fax line)
Cell: 618-553-0806
http://www.lorentedford.com
http://www.kc9zhv.com
http://hub.kc9zhv.com
FIXED!!
Don't know how or why, but in PulseAudio the source for the iaxrpt.exe record stream was switched from "Built in Analog Stereo" to "Monitor of Built in Analog Stereo".
Switched it back and it works fine. Thanks to George W2DB for getting me to look in the right direction. He said that sometimes his IaxRpt will not transmit if it does not detect the microphone.
Ed W8VT
