IAX registration problems
Ok… where am I going wrong? Running ACID, self managed server (not portal managed) and I can not get Asterisk to register to the registration server correctly. I am attempting to use port 4570 and set bindport=4570 in iax.conf.
If I do an iax2 show registry:
allstar*CLI> iax2 show registry
67.215.233.178:4569 N 2335 70.90.228.195:4569 60 Registered
It show registered, but not on the correct port ???
I also show the entry in /var/lib/asterisk/rpt_extnodes to be incorrect, it shows the IP I was previously using:
[root@allstar asterisk]# cat /var/lib/asterisk/rpt_extnodes | grep 2335
2335=radio@70.90.228.196:4570/2335,70.90.228.196
Anyone have any ideas? I’ve been off the air for a while due to hardware issues, and these configs were working previously, but it’s probably been a year or more…
tnx and 73,
Stephen
Stephen Brown - ARS K1LNX
Johnson City, TN EM86
http://www.k1lnx.net
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
SIP: k1lnx@k1lnx.net
Well the server you are connected too is using port 4569. I bet if a node connect to you they would use port 4570.
David
tnx and 73,
Stephen
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
That’s part of my issue, my 70.90.228.196 address is on an entirely different router, I am attempting to use 70.90.228.195 as my registered address, and unless I’m not looking at it correctly it is using port 4569 instead of 4570. If someone attempts to connect to me it will fail in it’s current state.
David
tnx and 73,
Stephen
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
I may be completely wrong here but I seem to recall you still need
to set the port in the network section of the server settings on
allstarlink.org even though it is not portal managed.
Steve
App_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
As for the public router address that would something to take up with your ISP. I would check it by using http://whatismyip.com.
Here is my registry. I do use 4570. Did you configure the allstarlink server that you are using 4570?
asl2063*CLI> iax2 show registry
67.215.233.178:4569 N 2081 72.67.127.136:4570 60 Registered
67.215.233.178:4569 N 2080 72.67.127.136:4570 60 Registered
67.215.233.178:4569 N 2064 72.67.127.136:4570 60 Registered
67.215.233.178:4569 N 2063 72.67.127.136:4570 60 Registered
David
David
tnx and 73,
Stephen
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Thanks… for clarification, I have 5 static IP’s from my provider. 4 of them live on one router (an atom based server running pfSense), the .196 sits on a seperate wireless router, completely isolated from everything else. It was cabled to that previously, but I moved it off of there as it was only there for temporary testing.
Yes, in the networking config section of the portal the port is set to 4570 and I have “custom (IP config set on VoIP server)” set in the dropdown menu. My theory is that once I have registered on the new IP it should have updated accordingly, I have restarted asterisk, rebooted, etc. and no luck :confused:
My guess at this point is maybe that it’s cached at the allstar server end and expires after a pre-determined length of time when an IP changes. Still can’t put a finger on the port thing though…
David
David
tnx and 73,
Stephen
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
I show you using port 4570 and IP address .195.
[root@asl2063 ~]# cat /var/lib/asterisk/rpt_extnodes | grep 2335
2335=radio@70.90.228.195:4570/2335,70.90.228.195
So it looks good now?
David
David
David
tnx and 73,
Stephen
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Weird… ok rather than second guess it, I’m going to blow away that file and reboot to get a fresh copy. It’s undoubtedly making it to the rest of the nodes :slight_smile:
David
David
David
tnx and 73,
Stephen
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
I tried to connect and no go. Maybe it was rebooting?
asl2063*CLI> rpt fun 2063 *32335
== Parsing ‘/var/lib/asterisk/rpt_extnodes’: Found
– Call accepted by 70.90.228.195 (format ulaw)
-- Format for call is ulaw
-- Hungup 'IAX2/70.90.228.195:4570-747'
-- Hungup 'Zap/pseudo-2145599652'
-- Hungup 'Zap/pseudo-1922206398'
-- <Zap/pseudo-103960313> Playing 'rpt/node' (language 'en')
-- <Zap/pseudo-103960313> Playing 'digits/2' (language 'en')
-- <Zap/pseudo-103960313> Playing 'digits/3' (language 'en')
-- <Zap/pseudo-103960313> Playing 'digits/5' (language 'en')
-- <Zap/pseudo-103960313> Playing 'rpt/connection_failed' (language 'en')
-- Hungup 'Zap/pseudo-103960313'
David
David
David
tnx and 73,
Stephen
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Still not making any progress on this, two questions:
  1. I blew away rpt_extnodes on the premise that it would return upon reboot, is that not the case? I did save a copy just in case…
  2. When I issue an iax2 reload, I see this in the console:
[Mar 22 18:32:07] NOTICE[2241]: chan_iax2.c:11430 set_config: Ignoring bindport on reload
Googling suggests this may be normal, but wasn’t sure. Nonetheless, I still am coming up on 4569, even after Asterisk restarts and reboots:
tnx
Stephen
K1LNX
David
David
David
tnx and 73,
Stephen
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Does your router support source-port preservation? If not, my guess is that
when the registration hits the Allstar server, it assumes you're on 4569 by
default. If you want to force it to another port, one of the portal
administrators has to do it for you.
The "ignoring bindport" is normal.
rpt_extnodes gets downloaded every 10 minutes.
        --- Jeff WN3A
-----Original Message-----
[mailto:app_rpt-users-bounces@ohnosec.org] On Behalf Of
Stephen - K1LNX
Sent: Tuesday, March 22, 2011 9:43 PM
To: app_rpt list
Subject: Re: [App_rpt-users] IAX registration problems
just in case...
Googling suggests this may be normal, but wasn't sure.
  Refresh State
       60 Registered
tnx
Stephen
K1LNX
On Tue, Mar 22, 2011 at 8:50 PM, Stephen - K1LNX > <k1lnx@k1lnx.net> wrote:
  Weird.... ok rather than second guess it, I'm going to
blow away that file and reboot to get a fresh copy. It's
    David
    On Tue, Mar 22, 2011 at 8:45 PM, Stephen - > K1LNX <k1lnx@k1lnx.net> wrote:
      Thanks... for clarification, I have 5
static IP's from my provider. 4 of them live on one router
      > Did you configure the allstarlink
of the portal the port is set to 4570 and I have "custom (IP
config set on VoIP server)" set in the dropdown menu. My
it's cached at the allstar server end and expires after a
pre-determined length of time when an IP changes. Still can't
put a finger on the port thing though...
using 4570?
        Host dnsmgr
        David
        On Tue, Mar 22, 2011 at 8:18 > PM, Stephen - K1LNX <k1lnx@k1lnx.net> wrote:
          That's part of my
address, and unless I'm not looking at it correctly it is
connect to me it will fail in it's current state.
          On Tue, Mar 22, 2011 at > 8:10 PM, David KE6UPI <dshaw@ke6upi.com> wrote:
            Well the server
            David
            On Tue, Mar 22, > 2011 at 7:47 PM, Stephen - K1LNX <k1lnx@k1lnx.net> wrote:
              Ok...
              If I do
              Host
       60 Registered
              It show
              I also
grep 2335
              Anyone
have any ideas? I've been off the air for a while due to
but it's probably been a year or more.....
              tnx and 73,
              Stephen
              Stephen
Brown - ARS K1LNX
              Johnson
City, TN EM86
              Allstar
Link: 2335
              IRLP: 4829
              PSTN:
423-665-9367
              SIP:
k1lnx@k1lnx.net
ohnosec.org
          Allstar Link: 2335
          IRLP: 4829
          PSTN: 423-665-9367
ohnosec.org
      Allstar Link: 2335
      IRLP: 4829
      PSTN: 423-665-9367
ohnosec.org
  Allstar Link: 2335
  IRLP: 4829
  PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Making some progress… I ended up shifting some firewall rules around and I am now registering on port 4570 externally:
67.215.233.178:4569 N 2335 70.90.228.195:4570 60 Registered
I am not showing up on the online nodes list however, and my rpt_extnodes has still not updated (still showing old IP).
A little baffled at this point, rc.updatenodelist is running, but doesn’t appear to be working as intended.
tnx
Stephen
K1LNX
when the registration hits the Allstar server, it assumes you’re on 4569 by
The “ignoring bindport” is normal.
                            --- Jeff WN3A
Stephen - K1LNX
To: app_rpt list
just in case…
  1. When I issue an iax2 reload, I see this in the console:
Refresh State
   60  Registered
tnx
Stephen
K1LNX
On Tue, Mar 22, 2011 at 8:50 PM, Stephen - K1LNX > > > k1lnx@k1lnx.net wrote:
  On Tue, Mar 22, 2011 at 8:48 PM, David KE6UPI >  > > <dshaw@ke6upi.com> wrote:
          2335=[radio@70.90.228.195:4570/2335,70.90.228.195](http://radio@70.90.228.195:4570/2335,70.90.228.195)
          David
          On Tue, Mar 22, 2011 at 8:45 PM, Stephen - >  > > K1LNX <k1lnx@k1lnx.net> wrote:
                  On Tue, Mar 22, 2011 at 8:34 PM, David >  > > KE6UPI <dshaw@ke6upi.com> wrote:
  1. Did you configure the allstarlink server that you are
using 4570?
                          Host                  dnsmgr
                          [67.215.233.178:4569](http://67.215.233.178:4569)   N
                          David
                          On Tue, Mar 22, 2011 at 8:18 >  > > PM, Stephen - K1LNX <k1lnx@k1lnx.net> wrote:
                                  That's part of my
                                  On Tue, Mar 22, 2011 at >  > > 8:10 PM, David KE6UPI <dshaw@ke6upi.com> wrote:
                                          Well the server
                                          David
                                          On Tue, Mar 22, >  > > 2011 at 7:47 PM, Stephen - K1LNX <k1lnx@k1lnx.net> wrote:
                                                  Ok...
                                                  If I do
                                                  Host
   60  Registered
                                                  It show
                                                  I also
grep 2335
                                                  Anyone
                                                  tnx and 73,
                                                  Stephen
                                                  Stephen
Brown - ARS K1LNX
                                                  Johnson
City, TN EM86
                                                  Allstar
Link: 2335
                                                  IRLP: 4829
                                                  PSTN:
423-665-9367
                                                  SIP:
k1lnx@k1lnx.net
                                  [http://www.k1lnx.net](http://www.k1lnx.net)
                                  Allstar Link: 2335
                                  IRLP: 4829
                                  PSTN: 423-665-9367
                  Allstar Link: 2335
                  IRLP: 4829
                  PSTN: 423-665-9367
  Allstar Link: 2335
  IRLP: 4829
  PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
I’m up now. It ended up being some firewall rules that weren’t NAT’ing things correctly. I’ve corrected and it appears to be working now.
tnx and 73…
Stephen
K1LNX
tnx
Stephen
K1LNX
                            --- Jeff WN3A
Stephen - K1LNX
To: app_rpt list
just in case…
Refresh State
   60  Registered
tnx
Stephen
K1LNX
On Tue, Mar 22, 2011 at 8:50 PM, Stephen - K1LNX > > > > > k1lnx@k1lnx.net wrote:
  On Tue, Mar 22, 2011 at 8:48 PM, David KE6UPI > >  > > > <dshaw@ke6upi.com> wrote:
          David
          On Tue, Mar 22, 2011 at 8:45 PM, Stephen - > >  > > > K1LNX <k1lnx@k1lnx.net> wrote:
                  On Tue, Mar 22, 2011 at 8:34 PM, David > >  > > > KE6UPI <dshaw@ke6upi.com> wrote:
using 4570?
                          Host                  dnsmgr
                          David
                          On Tue, Mar 22, 2011 at 8:18 > >  > > > PM, Stephen - K1LNX <k1lnx@k1lnx.net> wrote:
                                  That's part of my
                                  On Tue, Mar 22, 2011 at > >  > > > 8:10 PM, David KE6UPI <dshaw@ke6upi.com> wrote:
                                          Well the server
                                          David
                                          On Tue, Mar 22, > >  > > > 2011 at 7:47 PM, Stephen - K1LNX <k1lnx@k1lnx.net> wrote:
                                                  Ok...
                                                  If I do
                                                  Host
   60  Registered
                                                  It show
                                                  I also
grep 2335
                                                  Anyone
                                                  tnx and 73,
                                                  Stephen
                                                  Stephen
Brown - ARS K1LNX
                                                  Johnson
City, TN EM86
                                                  Allstar
Link: 2335
                                                  IRLP: 4829
                                                  PSTN:
423-665-9367
                                                  SIP:
k1lnx@k1lnx.net
                                  Allstar Link: 2335
                                  IRLP: 4829
                                  PSTN: 423-665-9367
                  Allstar Link: 2335
                  IRLP: 4829
                  PSTN: 423-665-9367
  Allstar Link: 2335
  IRLP: 4829
  PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
Allstar Link: 2335
IRLP: 4829
PSTN: 423-665-9367
