iax provisioning
Hi Guys;
One of the nodes that I administer is giving the following error, when trying to do an iax2 reload:
  iax2 reload
   == Parsing '/etc/asterisk/iax.conf': Found
[Mar 7 10:19:44] NOTICE[2839]: chan_iax2.c:10022 set_config: Ignoring bindaddr on reload
   == Loaded firmware 'iaxy.bin'
[Mar 7 10:19:44] NOTICE[2839]: iax2-provision.c:518 iax_provision_reload: No IAX provisioning configuration found, IAX provisioning disabled.
Consequently, no IAX connections (inbound or outbound) are being accepted.
Any ideas?
TIA,
Ramesh.
I have this exact same issue, I was trying to setup an IAX trunk to another machine and encountered the same error upon reload.
I haven't tested it, but I suspect my IAX connections are failing as well.
Stephen
K1LNX
Sent from my iPhone
On Mar 7, 2010, at 10:22, "Ramesh Dhami (VA3UV)" <Ramesh@va3uv.com> wrote:
Hi Guys;
iax2 reload
bindaddr on reload
Any ideas?
TIA,
Ramesh.
App_rpt-users@qrvc.com
These aren't error messages at all. They are NOTICE messages.
#1 Ignoring bindaddress on reload.
   Because it's already bound. No need on a reload.
#2 Provisioning IAX configuration not found.
   This tells me you are't using the IAXy device and havn't attempted
   to provision this ATA device from your Asterisk machine.
You have nothing to worry from these two NOTICE messages.
   -73s, N0NKI -Eric
well.
Stephen K1LNX
On Mar 7, 2010, at 10:22, "Ramesh Dhami (VA3UV)" <Ramesh@va3uv.com> > wrote:
Hi Guys;
iax2 reload
bindaddr on reload
accepted.
Any ideas?
TIA, Ramesh.
Hi men,
IAX provisionning is for the old ATA form Digium, named IAXY or S101i.
The firmware and its config file is pushed to the ATA when registried to Asterisk.
So, you have no config file for such device in the correct directory, thats all... No Matter !
Bindaddr is another thing.
May be you haven't defined the Ethernet port to address (0.0.0.0 for all local ports on the machine is ok) ?
Best 73's from F6HQZ Francois
Le 08/03/2010 13:04, Stephen - K1LNX a �crit :
well.
Stephen
K1LNX
Sent from my iPhone
On Mar 7, 2010, at 10:22, "Ramesh Dhami (VA3UV)"<Ramesh@va3uv.com> > wrote:
Hi Guys;
  iax2 reload
bindaddr on reload
accepted.
Any ideas?
TIA,
Ramesh.
THanks for the clarification… I’ll take a look at it again tonight. I could not get my IAX trunk to work, and I am running on a different port.
On Mon, Mar 8, 2010 at 11:45 AM, F6HQZ f6hqz-m@hamwlan.net wrote:
Hi men,
Asterisk.
thats all… No Matter !
May be you haven’t defined the Ethernet port to address (0.0.0.0 for all
Best 73’s from F6HQZ Francois
I haven’t tested it, but I suspect my IAX connections are failing as
well.
Stephen
K1LNX
Sent from my iPhone
On Mar 7, 2010, at 10:22, "Ramesh Dhami (VA3UV)"Ramesh@va3uv.com > > > wrote:
Hi Guys;
iax2 reload
== Parsing ‘/etc/asterisk/iax.conf’: Found
bindaddr on reload
== Loaded firmware ‘iaxy.bin’
accepted.
Any ideas?
TIA,
Ramesh.
Stephen Brown - ARS K1LNX
Johnson City, TN EM86
http://www.k1lnx.net
google voice: 423-665-9367
sip: sbrown@voip.stephennet.net
