I just got an raspberry pi setup and running. node 55970. I able to connect going out. But not coming in to the node. I got the server Iax port set as 4569 and I got the ports on the router set to 4569 also. Is there something I Mit be missing. on doing inside of the raspberry pi. We just got fiber internet here. so first time I ben able try to get the node to take inbound calls. thank you
You need to port forward port 4569 UDP. Port forwarding both TCP and UDP will work but all you need is UDP.
Not sure what AllStar version you are using but there could be a firewall in your Pi too.
