I have temporarily stopped working on my AllStar node
That doesn’t look right… which document did you find that in?
Just for giggles, I tried it and it failed:
nessenj@nessenj-laptop:~$ ssh repeater@192.168.5.9:222
ssh: Could not resolve hostname 192.168.5.9:222: Name or service not known
Jim, K6JWN
@Charles , have you edited your /etc/ssh/sshd_config and allowed root login ?
PermitRootLogin yes
Of course you need root privileges to edit the file (sedo or su)\
After saving the edit
systemcontrol restart ssh
edit:
while you are in there, verify the port number used and change as needed before you save/exit.
Hi Mike, I finally got my node working okay. Thanks for asking.
Are you using powershell on windows?
Your prompt looks like linux, which it would not work on linux.
This would be the correct command on a linux terminal for port 222
ssh repeater@192.168.5.9 -p 222
