I forgot how to setup Callcentric again..
Here is the information i have so far… For some reason i just can’t make out going calls it seems to register with callcentric ok kinda confused as to where i might have mixed this up…
http://forum.kc9zhv.com/index.php/topic,22.0.html
So… Here is the errors i get when i try to make a call from my hand held…
[Nov 5 16:19:37] WARNING[2489]: chan_sip.c:2946 create_addr: No such host: callcentric
[Nov 5 16:19:37] WARNING[2489]: app_dial.c:1242 dial_exec_full: Unable to create channel of type ‘SIP’ (cause 20 - Unknown)
rpt*CLI>
Does my forum look correct? with out the username and password listed but still confused as to what i might have done wrong…
Loren Tedford (KC9ZHV)
Phone:618-553-0806
Fax: 1-618-551-2755
Email: lorentedford@gmail.com
Email: KC9ZHV@KC9ZHV.com
http://www.lorentedford.com
http://www.kc9zhv.com
http://hub.kc9zhv.com
http://Ltcraft.net
http://voipham.com
In /etc/modules.conf is sip loaded?
load => chan_sip.so ; Session Initiation Protocol (SIP)
Check against what I am using below, another issue I have run into is sometimes after boot I have to run
**asterisk -rx “sip reload” to get it to connect/work… **
Hope this helps…
SIP.conf:
; SIP Configuration example for Asterisk
[general]
context = default
; Default context for incoming calls
allowoverlap = no ; Disable overlap dialing support. (Default is yes)
bindport = 5060 ; UDP Port to bind to (SIP standard port is 5060)
bindaddr = 0.0.0.0 ; IP address to bind to (0.0.0.0 binds to all)
srvlookup = yes ; Enable DNS SRV lookups on outbound calls
; Note: Asterisk only uses the first host
; in SRV records
; Disabling DNS SRV lookups disables the
; ability to place SIP calls based on domain
; names to some other SIP users on the Internet
dtmfmode = rfc2833
context=from-callcentric
srvlookup=yes
register => 1777:YOURPASSWORDHERE@callcentric.com
session-timers=refuse
[callcentric]
type=peer
host=callcentric.com
fromdomain=callcentric.com
username=1777…
fromuser=1777…
secret=YOURPASSWORDHERE
insecure=port,invite
canreinvite=no
disallow=all
allow=ulaw
[100] ;this is your extension # at call centric. usually 100-150
context=to-callcentric
type=friend
defaultuser=1777…
host=dynamic
Extensions.conf:
[to-callcentric]
exten => _X.,1,Dial(SIP/${EXTEN}@callcentric)
RPT.conf:
6=autopatchup,context=to-callcentric,noct=1,farenddisconnect=1,dialtime=20000
rpt*CLI>
Phone:618-553-0806
Fax: 1-618-551-2755
http://Ltcraft.net
http://voipham.com
“Got Root?”
How many software engineers does it take to change a light bulb?
None. It’s a hardware problem.
Unix is user friendly. It’s just very particular about who it’s friends are.
WINDOWS: Will Install Needless Data On Whole System
MICROSOFT: Most Intelligent Customers Realize Our Software Only Fools Teenagers.
A ntennas
P oorly
P laced
L acks
E ngineering
The best way to accelerate a computer running Windows is at 9.81 m/s².
“I get paid to support Windows, I use Linux to get work done.”
