I can not complete registration form
I have supplied all my personal data
and the Captcha, however the SUBMIT
button is never active.
Do you have an adblocker or are running one of the privacy browsers like Brave? Make sure that one of those tools isn't blocking the Captcha domain.
Pretty plain vanilla Safari.
Are you talking about signing up for an account on allstarlink.org..? Because I show a valid/active account since 8/25.
OK. I must have created an account there. I just logged in using my call sign as username and a password. However, while I have the account there, I can not get DV Switch to accept whose credentials for WT mode. It always says login failed when I try to update the token.
Try resetting the account password and restarting everything. DVSwitch WebTranceiver mode uses your webportal login credentials for that token thing.
If it still doesn’t work, I’d run it by Steve N4IRS on the DVSwitch Mobile groups.io.
You need an actual running node (not just an orphaned node number) to connect to your own node; it shouldn’t affect the login though.
I believe DVSwitch’s Node Mode can use just a node number though, because you become the node.
