I have port 4569 UDP open on my router and pointing to my Allstar node. I can connect to other nodes but other nodes can not connect to me. I used GRC Heads Up to probe my public IP and it shows 4569 is not open. I did a port probe directly on the LAN and it shows 4569 is not open on the Allstar node. I checked iax.conf and 4569 is set correctly there. I checked the firewall rules and 4560 through 4590 are allowed. What am I missing?
Try the ipvoid.com UDP port scanner. That worked for me, but Ping Tools did not.
Steve,
Thank you so much. The tools I was using did not return the actual
status. Ipvoid shows the port is open on the public net. I appreciate
your help.
-Rick
On 9/4/2020 8:03 AM, Steve Arntz via AllStarLink Discussion Groups wrote:
[Steve_Arntz] Steve_Arntz
https://community.allstarlink.org/u/steve_arntz
September 4Try the ipvoid.com http://ipvoid.com UDP port scanner. That worked
for me, but Ping Tools did not.image
https://community.allstarlink.org/uploads/default/original/2X/3/31291e3aabcaeb850522607971632a7122cf493b.pngVisit Topic
https://community.allstarlink.org/t/i-can-connect-to-other-nodes-but-other-nodes-can-not-connect-to-mine/17519/2
or reply to this email to respond.To unsubscribe from these emails, click here
https://community.allstarlink.org/email/unsubscribe/68c5a69e30eee32c72d9b9a774ca372b776d57b4faffefe9f926fda5269a6820.
*Rick Swenton
Amateur Radio Operator W1RHS
- South Dennis, MA, USA*
*_____________________________________
+1-860-836-7621 / Rick@Swenton.COM mailto:Rick@Swenton.COM
“Creative activity is a type of learning process where the teacher and
pupil are located in the same individual.”― Arthur Koestler
Steve, I spoke too soon. The port is Open,Filtered. At least I am one
step closer. -Rick
*Rick Swenton
Mine is filtered too according to the tool. I like to use Putty for a terminal window. You can try the command asterisk -rvvv and see what errors you may receive on connect attempt from the outside.
On Fri, Sep 4, 2020 at 8:43 AM Rick Swenton via AllStarLink Discussion Groups <noreply@community.allstarlink.org> wrote:
| Rick_Swenton
September 4 |
step closer. -Rick
In Reply To
| Steve_Arntz
September 4 |
Try the ipvoid.com UDP port scanner. That worked for me, but Ping Tools did not. [image]
What is your node number and is the node online now?
My node successfully connected to 522710 this morning.
Thanks trusty. I guess I am chasing my tail. I finally installed nmap
and that shows 4569 UDP is open on the node. IPVoid is showing
Open>filtered on the public IP. I changed my node LAN static IP to a
lower number because my Netgear router was reported to have a bug with
port forwarding higher IP addresses. 73 -Rick
On 9/4/2020 12:16 PM, w7efs via AllStarLink Discussion Groups wrote:
[trusty] trusty https://community.allstarlink.org/u/trusty
September 4My node successfully connected to 522710 this morning.
Visit Topic
https://community.allstarlink.org/t/i-can-connect-to-other-nodes-but-other-nodes-can-not-connect-to-mine/17519/7
https://community.allstarlink.org/email/unsubscribe/c2fe9276639851f9f37e42b48a139e620bef0a8031341e17335867d9902aa932.
*Rick Swenton
