What if anything are the specific differences between a single node (tied to simplex, repeater, Pi box and headset…) that can presumably only accept one in-bound call/connect, and a hub, to which many can connect and bridge through/over?
Given a certain amount of specialization or purpose/interest-built hubs I am interested in having a purpose-built hub for a few systems and users not exclusive but so as not to impose on others’ hubs and traffic.
Any node can be a "HUB" A node is not limited to one connection.
There may be hardware limitation about the number of connections a
given piece of hardware and internet connection can support.
Typically, a HUB is located on a higher bandwidth internet
connection and is running a more “stout” piece of hardware. A HUB
usually does not have a node radio connected to it, but there is no
reason it can’t. A HUB usually runs DAHDI/pseudo for it’s rxchannel.
As a example HUB 2100 is running on a decent internet connection and
decent hardware. We are running the beta test of the DMR <—>
AllStar gateway on it so it has a NW Digital DV3000 connected and is
using chan_usrp instead of pseudo for it’s rxchannel.
Hope this helps.
73, Steve N4IRS
On 2/14/2016 5:24 PM, Jim Aspinwall
wrote:
What
Given
What
does it take to do this?
Jim,
Any node can be a "HUB" A node is not limited to one connection. There may be hardware limitation about the number of connections a given piece of hardware and internet connection can support. Typically, a HUB is located on a higher bandwidth internet connection and is running a more "stout" piece of hardware. A HUB usually does not have a node radio connected to it, but there is no reason it can't. A HUB usually runs DAHDI/pseudo for it's rxchannel.
As a example HUB 2100 is running on a decent internet connection and decent hardware. We are running the beta test of the DMR <---> AllStar gateway on it so it has a NW Digital DV3000 connected and is using chan_usrp instead of pseudo for it's rxchannel.
Hope this helps.
73, Steve N4IRS
On 2/14/2016 5:24 PM, Jim Aspinwall wrote:
What if anything are the specific differences between a single node (tied to simplex, repeater, Pi box and headset...) that can presumably only accept one in-bound call/connect, and a hub, to which many can connect and bridge through/over?
Given a certain amount of specialization or purpose/interest-built hubs I am interested in having a purpose-built hub for a few systems and users not exclusive but so as not to impose on others' hubs and traffic.
Have several nodes running on allstarlink, some x86 and some raspberry pi2’s. I have noticed the false dtmf issue on each node and would like to recompile app_rpt to set the radio relax feature accordingly to reduce/eliminate the false dtmf tones that get decoded from voice transmissions. All nodes are running the latest dial installation, does anyone know the correct procedure to do this on a dial system?
[http://docs.allstarlink.org/drupal/node/170](http://docs.allstarlink.org/drupal/node/170)
Kevin
On 2/15/2016 9:54 AM, Steve Zingman wrote:
Jim,
no reason it can’t. A HUB usually runs DAHDI/pseudo for it’s
rxchannel.
<—> AllStar gateway on it so it has a NW Digital DV3000
connected and is using chan_usrp instead of pseudo for it’s
rxchannel.
Hope this helps.
73, Steve N4IRS
hubs and traffic.
Stop asterisk:
service asterisk stop
Verify asterisk is stopped:
ps ax | grep asterisk If you see� /usr/sbin/asterisk it is not
stopped
�killall -9 asterisk
stopped
Change compiler setting:
cd /usr/src/astsrc-1.4.23-pre/asterisk
make menuselect
select� 10. Compiler Flags
select 6.� RADIO_RELAX set to taste
x
make
make install
service asterisk start
73, Steve N4IRS
On 2/16/2016 9:33 AM, Bryan Taylor
wrote:
Hello all,�
allstarlink, some x86 and some raspberry pi2’s. �I have noticed
voice transmissions. �All nodes are running the latest dial
on a dial system?
Bryan
Vo1mxz
Sent from my iPhone 6
On Feb 15, 2016, at 12:34 PM, Kevin Custer < >
wrote:
To unsubscribe from this list please visit [](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
You do not need a password to unsubscribe, you can do it
via email confirmation. If you have trouble unsubscribing,
“stout” piece of hardware. A HUB usually does not have a
node radio connected to it, but there is no reason it can’t.
of the DMR <—> AllStar gateway on it so it has a NW
Hope this helps.
73, Steve N4IRS
Aspinwall wrote:
What if anything
Given a certain
ps ax | grep asterisk If you see /usr/sbin/asterisk it is not stopped
killall -9 asterisk
make menuselect
select 10. Compiler Flags
select 6. RADIO_RELAX set to taste
x
make
make install
73, Steve N4IRS
On 2/16/2016 9:33 AM, Bryan Taylor wrote:
Hello all,
Have several nodes running on allstarlink, some x86 and some raspberry pi2's. I have noticed the false dtmf issue on each node and would like to recompile app_rpt to set the radio relax feature accordingly to reduce/eliminate the false dtmf tones that get decoded from voice transmissions. All nodes are running the latest dial installation, does anyone know the correct procedure to do this on a dial system?
