OS Kernel : 6.12.25+rpt-rpi-2712
Asterisk : 22.4.1+asl3-3.5.4-1.deb12
ASL [app_rpt] : 3.5.4
I am trying to set up a hub/node on a Raspberry Pi 5. I will be using it to connect a 440 mhz repeater and a 6 meter repeater and I want other nodes to be able to connect to my hub through AllStatLink. I have gone through the initial setup and configured it as a hub with no radio. What other changes to the .conf files do I need to make?
I have read through all the online help on this site and other internet sites.
If its working then nothing really. The rest is all just "addons and touch ups" if you want to call them that. I was able to connect to 65640 just fine
It was actually easier then I thought when I setup my two nodes. Just remember that each node has to have its own port number and they have to point to each other. If you have questions just reach out.
