I was giving a talk last night on ASL V3 and an observant listener pointed out that the Web Admin Portal(Cockpit) is https but the Node Links(Allmon3) is http and NOT https!!!
Why?
This means the Allmon3 login username and password are being sent in the clear.
This is an up to date Pi-appliance node(RPi4B 4 GB).
I did more investigation:
I tunneled to the LAN behind the router where this node is located and tried local https access and sure enough https works there for Dashboard, Cockpit, and Allmon3.
The confusing part was why the Cockpit used https and Allmon3 did not.
Port 9090 (Cockpit) is port forwarded in the router to the ASL node.
A 5 digit WAN port number is port forwarded to LAN port 80 on the ASL node.
For Allmon3, and the Dashboard, I think I need to figure out how to port forward the 5 digit port number to both ports 80 & 443.
Can I port forward that 5 digit port number to both port numbers 80 and 443?
Maybe I should just Port forward the 5 digit WAN port number to LAN port 443 and not port forward port 80 and block it at the ASL Firewall?
For nodes with a public IP what’s the best way to handle this?
Block port 80 in FirewallD and change Apache2 to use something other than port 443 and port 80?
Since for one node where the Wireguard client is installed on the node, I could block the http port in FirewallD and make sure to not block the https port.
On another node I have behind a router, I only port forwarded the https port and not the http port. For added obscurity, the WAN https port number is not the same as the LAN https port number. I do the same for ssh.
