UPDATE: Found the problem in the SimpleUSB config file. It needed to be set for the preferred simplex setting. Problem solved.
Radio-to-Computer Interface: RIM-ALINCO Board for AllStarLink (Repeater Builders).
Radio: Alinco DR-135 Mk III
TYT Model MD-UV380
My HT connection to my ASL node (via the node-attached radio) passes all the “tests” under the SimpleUSB tuning menu.
Active radio interface is [usb_567160]
Device String is 1-1.1.3:1.0
Card is 1
Rx Level currently set to 450
Tx A Level currently set to 750
Tx B Level currently set to 750
- I have adjusted “Set Rx Voice Level (using display)” to bob around just under the 5KHz level.
- Transmit Levels A & B are set to 750 (as confirmed above).
- Toggle Echo Mode produces a perfect audio playback.
- I can hear myself on other HTs listening to my node radio.
- Flash toggles PTT & transmits a tone.
- All parameters are properly saved via the “W” menu option.
Yet, no one can hear me when I key up for a net though I can hear them perfectly.
This does NOT happen when I’m using the Transceive ASL App on my MacBook Pro. I can be heard without any problems. I can hear my voice being transmitted from the HT through the Transceive App.
I control the linking/unlinking via the HT keypad with no problems.
Any suggestions as to what to check? As far as I can tell, the HT audio is not getting passed on to ASL.
Thank you.
