Date: 2009/06/15 Mon PM 02:15:06 PDT
To: app_rpt <app_rpt-users@qrvc.com>
Subject: [App_rpt-users] How to update...?I have the latest version of ACID installed on 6+ nodes. I know that
the astupd.sh script will at some time update the app_rpt and
irlp/echolink channels, but in a step by step how would one get the
latest builds (Bleeding edge) installed and built?Mark
KC5EVE_______________________________________________
App_rpt-users@qrvc.com
There is no step-by-step guide to doing this as it is not a canned process. This is really something only a developer or tester should attempt. Tinkering with the latest code on production systems is not advised. If you have a sandbox system, you can check out the files using SVN then copy them over the top of the existing files in /usr/src using cp, then manually recompile everything, and restart your system. How to access SVN is noted here:
http://app-rpt.qrvc.com/node/6
Steve
WA6ZFT
