Hey gang, I’ve been using allstarlink since 2009. And, of course, when Jim was still with us this confusion didn’t exist but… I have a node configured to go into service on a 900 repeater in about a month. The computers I use are HP Thin Clients with 16GB SSD. It works but I just went noodling around the /usr/local/sbin directory and saw “write-node-callsigns” And when it errored I looked at the script itself and saw reference to hamvoip and it was written by Doug DSP.
So question: how do I tell if I’m using HamVoip or the real deal?
GeorgeC W2DB
One way to tell if you are running ASL is by checking the OS version. Hamvoip runs Arch Linux, ASL does not. Do a cat /etc/os-release and see what you get.
6AWP to the memory rescue again. Thanks. Hate this getting older crap. I totally forgot that they used ARCH. This is definitely Debian, I know because it’s actually possible to navigate the file system. HATE ARCH. Like their package manager, though. Also, I dug further and found the source code and was able to re-compile. Somehow when I did this a year or so back I actually had de-selected app_rpt in menuselect “1.Applications” but…it worked as a repeater controller fine. But some of the functions didn’t work. Go figure. I knew something was wrong because changing the morse speed did nothing… Anyhow all’s good.
