Add this to your rpt.conf
outstreamcmd=/bin/sh,-c,/usr/bin/lame --preset cbr 16 -r -m m -s 8 --bitwidth 16 - - | /usr/bin/ezstream -qvc /etc/ezstream.xml
I put it above the [Morse…] section - for the node you want to broadcast
keep it all on one line btw -
***** Please Note ***** It has been a while since I used the instructions here but they should work on Cent OS 5.x
Do NOT just run the EZS script - it is only written as a guide -
attached is a .tgz file with everything you should need -
to decompress I put it in the /root folder
at the shell run -
tar -xvhf ezs.tgz
That should extract the files to the ezs directory -
If you have any questions please let me know.
----- Edit the ezstream file - ezstream.xml -----
http://audio9.radioreference.com:80/#######
PW####
MP3
stdin
NAME###
http://www.radioreference.com/
Amateur Radio
DESCRIPTION
16
1
22050
1
ezs.tgz (52.8 KB)
“Got Root?”
How many software engineers does it take to change a light bulb?
None. It’s a hardware problem.
Unix is user friendly. It’s just very particular about who it’s friends are.
WINDOWS: Will Install Needless Data On Whole System
MICROSOFT: Most Intelligent Customers Realize Our Software Only Fools Teenagers.
A ntennas
P oorly
P laced
L acks
E ngineering
The best way to accelerate a computer running Windows is at 9.81 m/s².
“I get paid to support Windows, I use Linux to get work done.”
On Thu, Apr 24, 2014 at 7:18 AM, Loren Tedford lorentedford@gmail.com wrote:
Hello my name is Loren I would like to set up a live audio stream from my repeater to broadcastify if anyone has any suggestions on how or what i should do this would be appreciated. I would much rather if I could just take the audio from the repeater its self rather than setting up a secondary scanner then reroute it back to broadcastify… Using Acid Linux Distro all normal install… URI connected to two GM300s etc…
Any suggestions on this idea and if you have done this before please let me know how ya did this or what i need to do to get started 73’s for now.
Loren Tedford (KC9ZHV)
Email: lorentedford@gmail.com
Email: loren@lorentedford.com
http://www.lorentedford.com
