How to setup usbRadio setup with cm108?
I am used with usbinvert using simpleusb setup with cm108 and a radio with COS.
I am trying out usbRadio with DSP for carrier sensing and Im a bit on trouble. Do I need to connect the pin 48 to something or just leave it unconnected?
Sharing your usbRadio.conf settings would help a lot.
Using USB DSP you will need raw un-deemphasis audio from the radio and transmit audio to the radio.
Kind of a Pain to configure. Instead SimpleUSB.conf you use USBradio.conf so you also need to configure your rpt.conf for that.
Hard to get a cos pin from the radio that I will be using.
Getting Flat audio will be harder than getting a COS signal.
