Hello,
Is it possible to install a Webserver and FreePBX on server, where is installed ACID ?
I have idea to make a voting repeater with RTCM boards and use other PBX functions, as conferences, IVR and more. If I really understand, ACID distro don’t have Asterisk webserver and graphical interface. I am not a Linux guru… If it possible, could you help me with FreePBX install instuctions (I have a just new install from ACID)
I need a private voting repeater network (1 server PC with Static IP, 3 voting receivers with RTCM boards, 1 or 2 Transmitters with RTCM boards, and any sip clients, softphone clients)
Thank you!
Both ACiD and the FreePBX distro run on CentOS. ACiD, if I am not
mistaken runs CentOS 5 and I know, because I have it, FreePBX distro
comes with CentOS 6.
You can roll your own Allstar link, it's really just configuration. You
will need to make some significant changes.
I have FreePBX 2.10, and I don't think I like it compared to the layout
of 2.9 and previous versions.
~Benjamin, KB9LFZ
Allstar node 28569
On Fri, 2013-05-17 at 20:35 +0300, Mihhail Jakovlev wrote:
Hello,
installed ACID ?
Thank you!
ohnosec.org
May be possible to install chan_voter to any another Distro, as XIPPR or EasyVoxBox? Important is RTCM board using possibility.
Another way is use a PC with ACID for Voting repeater and other PC with XIPBX for other PBX functions and separate radionodes. PBX is a trunk for ACID server.
Mihhail
ES1BIS
-----Original Message-----
From: Benjamin L. Naber [mailto:Benjamin@kb9lfz.com]
Sent: Saturday, May 18, 2013 3:15 AM
To: Mihhail Jakovlev
Cc: app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] How to install FreePBX to ACID?
Both ACiD and the FreePBX distro run on CentOS. ACiD, if I am not mistaken runs CentOS 5 and I know, because I have it, FreePBX distro comes with CentOS 6.
You can roll your own Allstar link, it's really just configuration. You will need to make some significant changes.
I have FreePBX 2.10, and I don't think I like it compared to the layout of 2.9 and previous versions.
~Benjamin, KB9LFZ
Allstar node 28569
Hello,
installed ACID ?
Thank you!
ohnosec.org
"May be possible to install chan_voter to any another Distro, as XIPPR or
EasyVoxBox? Important is RTCM board using possibility. " – Nope… not without a lot of mods to other “stuff”.
"Another way is use a PC with ACID for Voting repeater and other PC with XIPBX for other PBX functions and separate radionodes. PBX is a trunk for ACID server. " – Yep… probably the best compromise
Jim WB6NIL
Date: Sat, 18 May 2013 20:49:07 +0300
To: Benjamin@kb9lfz.com
CC: app_rpt-users@ohnosec.org
Mihhail
ES1BIS
You can roll your own Allstar link, it’s really just configuration. You will need to make some significant changes.
I have FreePBX 2.10, and I don’t think I like it compared to the layout of 2.9 and previous versions.
~Benjamin, KB9LFZ
Allstar node 28569
Hello,
installed ACID ?
Thank you!
ohnosec.org
ohnosec.org
