Hi guys im not overly savvy with allstar and need some help…
im wondering if there is a way to either send a dtmf command to enable / disable the ToT on allstar
or
a timed cron tab to do the same at certain time’s
thanks all
regards sean
or
thanks all
regards sean
I believe you are looking for COP commands 7 & 8 which can be exercised using macros using a dtmf command. See Rpt.conf - AllStarLink Wiki
Bob
K6ECM
In /etc/asterisk/rpt.conf
Whatever DTMF you have assigned to these (in this case 914 & 915) can be directly entered.
914=cop,7 ; Time out timer enable
915=cop,8 ; Time out timer disable
The timer itself
totime =
If you use control states
totena
totdis - Timeout timer Enable/Disable
mike thanks
so i can simply use for example DTMF 999 which = cop7 and this will enable the tot
do i need to add any further script anywhere…?
if needed i dont mind copying and pasting my rpt.conf file for a read and see if i can set this up…
cheers
As dtmf from phone or radio *999
if that points to cop,7
999=cop,7
Look in the file and be sure that cop7 has not yet been defined before you add the new.
If you are using winscp for editing, you can use the ‘find’ feature in the file to find cop,7
my hub node looks like this
and I think these were defaults with version 1.01 of the software.
907 = cop,7 ; Time out timer enable|
908 = cop,8 ; Time out timer disable|
Control States are one way to do this and is particularly if you want to set your node to a “net mode” for example.
For control states see Rpt.conf - AllStarLink Wiki
And for scheduling see Scheduler (ASL System) - AllStarLink Wiki
Thankyou guys i will try these…
Regards sean M0oeg
