Whenever I connect my Allstar node to another node, my node will locally announce:
"node --- Connected to node ---".
How do I disable this? I use Allscan and Allmon3 to connect and disconnect my node so I can see what is happening, and I don't need the node to announce the connection stats.
I have tried with no luck:
holdofftelem=1
telemdefault=2
telemdefault = 0 will definitely suppress connect messages.
Yes
Thanks for your help.
telemdefault = 0 is now set to 0
xxxx=cop,34 ; Local Telemetry Output Disable
xxxx=cop,33 ; Local Telemetry Output Enable
xxxx=cop,35 ; Local Telemetry Output on demand
xxxx=cop,37 ; Foreign Link Local Output Path Disable
xxxx=cop,36 ; Foreign Link Local Output Path Enable
xxxx=cop,38 ; Foreign Link Local follow local telem
xxxx=cop,39 ; Foreign Link Local Output Path On-/-Timed
And when thst doesn't stop the announcements, then what?
Ok I might set this up
Format the SD card and start again
Except the affected node isn't a Pi
I had the same Idea and I am running a 2011 Macbook Air to drive my node but I never had any issues. Once I put in all the right numbers it all worked.
