I discovered the following which cleared many Gb of space from both of my nodes.
apt clean
apt autoclean
apt autoremove
Had a similar problem once when upgrading to Trixie. Clear the logs. Look at the journalctl command. Run the df command before and after to check free space.
Steve
N5TIN
and don't neglect sudo journalctl --vacuum-size=256M to leave just 256MB of logs around
Specifically with the rPi image, unless you change it, logs are written to RAM anyway, so they will not survive a restart. /TMP is mounted as a 128 MB block of RAM.
Aren’t package update logs in /var/log/apt?
Pretty sure that is where I had my issue.
Steve
N5TIN
I just looked at /etc/fsbat again. Here is the relevant stuff. Everything in /var/log/ is persistent except for:
tmpfs /tmp tmpfs defaults,noatime,nosuid,nodev,noexec,mode=1777,size=128M 0 0
tmpfs /var/tmp tmpfs defaults,noatime,nosuid,nodev,noexec,mode=1777,size=128M 0 0
Delete/comment out the next line for persistent Apache logs
tmpfs /var/log/apache2 tmpfs defaults,noatime,nosuid,nodev,noexec,mode=0775,size=32M 0 0
Delete/comment out the next line for persistent Asterisk logs
tmpfs /var/log/asterisk tmpfs defaults,noatime,nosuid,nodev,noexec,mode=0775,size=32M,uid=102,gid=1>
