How do I view the gzip'd.text archives?
In the archives list on the right hand side you can download the months archives into a txt.gz file. How can I view these. I have tried the instructions found at http://johnpoelstra.com/tag/import/ with his example with no problems but when I apply the same instructions to the file found on this list I have no luck. Ideally I would like to import them into Thunderbird or something similar for easy searching.
Mike - N3KPU
gunzip filename.gz on Linux
7zip on Windows
David
Mike - N3KPU
I have done that part but when I try to open the file you can read the first line which is a header that shows the path and file name but after that it is just a bunch of random characters. I have done this under both XP and Ubuntu with practically the same result.
Mike
7zip on Windows
David
Mike - N3KPU
