Hi All, I know this has been asked before.
I have 2 node boxes and would like to put both on the same router/IP. I would like to change the def port on one of the nodes to 4568 so I can operate both boxes.
The first server has 4 nodes on it already and maxed out on the USB ports. So using second box to add an extra node.
I remember somebody saying that a change must be made in the node and the folks at Allstar have to set something in the server?
The first 2 lines of the iax.conf file in the [general] stanza generally
are:
bindport=4569
bindaddr=0.0.0.0
Just make the “bindport” whatever port you want it to be, and dont forget to
change the port number for the server in the Allstar portal, so that it will
get announced properly.
JIM WB6NIL
Date: Sat, 2 Oct 2010 09:45:17 -0400
To: app_rpt-users@qrvc.com
Subject: [App_rpt-users] how do I change default port from 4569 to 4568 on node?
operate both boxes.
OK well I made the changes to IAX.conf and the portal server setting and works fine here. One thing I found though doing the bind thing is IAX_RPT wont connect to that node now. Not sure if its something to do with IAXRPT or do I have to change something else to get that working again?
Perhaps Steve W9SH can comment on that.
I am using a linksys WRT54GL router with DDWRT on it. Do you know it it will do PAT??
Would be nice to know.
Jon
On 10/2/2010 3:44 PM, Ken wrote:
Actually - there is one other approach besides bind port - advice that was
given to me - was to get a router that supports PAT.
That way the configuration in the various computers stays the same.
Port Address Translation allows you to have different ports on the same node
on the WAN side and all the SAME port on the LAN side - but with different
node numbers.
I suppose, had I known better at the time, I would have gone for the "free"
solution. But the new router lets me run my local system at 1Gb, which is
nice, as I have 3 Linux boxes (so far) and 3-5 PCs on the network. It's kind
of addictive .....
Ken
-----Original Message-----
Sent: Saturday, October 02, 2010 12:01 PM
To: 'jrorke@cogeco.ca'
Subject: RE: [App_rpt-users] how do I change default port from 4569 to
4568 on node?
You need to make a 'new' server for the new computer and you can
specify whatever port you want there at the portal config.
Nothing needs to be done by the system admins any more
GL
Ken
again?
will do PAT??
Jon
was
same node
different
node numbers.
"free"
which is
It's kind
of addictive .....
Ken
to
4568 on node?
GL
Ken
Perfect! works like a champ. I'm glad it is something simple. Didnt know you could specify the port too.
Thanks!
Jon
On 10/2/2010 4:44 PM, Steve Henke wrote:
Just change the Account's Host entry to the form:
ServerHostAddress:NonStdPortNum
e.g. w9sh.xelatec.com:4567 or 192.168.1.10:4567
73,
Steve, W9SH
again?
will do PAT??
Jon
was
same node
different
node numbers.
"free"
which is
It's kind
of addictive .....
Ken
to
4568 on node?
GL
Ken
Yep! IAX rpt been working fine for me. Just upgraded it too.
My op system here is win 2000. Works on my net book too on XP pro.
Friend of mine had problem with W7 64 though.
Something to do with sound drivers.
Real handy for the 20 some nodes I look after.
j
On 10/2/2010 5:51 PM, Ken wrote:
Oho! I see there is a new Iax_Rpt
I had tried it ~ a year ago along with a friend of mine and we could never
get it to work right. Volume sent from the PC was always too low - no matter
what. I posted something on the asterisk reflector but was directed over to
Xeletec. I posted a request on the Xeletec web site and it got zero replies
over the last 30 weeks.
Hopefully the new version fixes the problem !
I take it that it works FB for you?
Later
Ken
From: app_rpt-users-bounces@qrvc.com [mailto:app_rpt-users-
bounces@qrvc.com] On Behalf Of REDBUTTON_CTRL
Sent: Saturday, October 02, 2010 4:10 PM
To: APP_RPT_Users
Subject: Re: [App_rpt-users] how do I change default port from 4569 to
4568 on node?
again?
will do PAT??
Jon
that was
same node
different
node numbers.
"free"
which is
It's kind
of addictive .....
Ken
to
4568 on node?
GL
Ken
