How can I change server-not in drop down list
Asterisk Version: 22..x.y+asl3-3.n.m
ASL3 Version: 3.x.y
Inquiry
How can i change node to different server not in drop down. It needs to be register.allstarlink.org but Idon’t see that option. Do I need a new node?
Is this for DVSwitch mobile?
no just trying to get my node working
In that case I’m unclear what you’re trying to do. The online server has no web address to set, other than the proxy setting (which few ever use). The only setting of consequence is the IAX port setting.
On the portal you have your "Server" settings and your "Node" settings. In your case, you have 2 servers configured ("Allstarlink" and "KJ5ICR"). You also have a couple of nodes configured. In the settings for each node you choose the associated "server" (right column, top popup).
