host name for DHCP
Does any linux guru out there know how to change the DHCP client name from TEST?
I followed the instruction to use system-config-network and suceeded in changing the shell prompt to the host name I want, but my router still says the node name is TEST.
Some internet searching came up with the "dhclient" command - which works - but after the next lease renewal it is back to TEST again. That name must be buried someplace in the linux configuration.
Ken
Is this a centos/ACID box?
TRY adding or editing the "HOSTNAME=" line in:
/etc/sysconfig/network
Was almost able to do this from memory but had to google it
by searching for "centos change hostname"
Not everyone is going to know exactly what to search for.
:slight_smile: so I won't griping "google is your friend" anytime soon :slight_smile:
Tested here and works :slight_smile:
[root@N8LBV-R ~]#
-Steve
from TEST?
Ken
[email protected]
This message has been scanned for viruses and
dangerous content by MailScanner, and is
believed to be clean.
Michigan Broadband Systems Inc.
"Always Connected"
(734)527-7150
Steve's cellphone: (734)904-1811
from TEST?
Ken
[email protected]
It is usually very beneficial to search app-rpt.qrvc.com first:
http://app-rpt.qrvc.com/node/163
Steve
WA6ZFT
Thanks!
Good suggestion.
Better to do it this way :slight_smile:
-Steve
from TEST?
Ken
[email protected]
Steve
WA6ZFT
[email protected]
"Always Connected"
(734)527-7150
Hi Ken,
I don't know if this is ok for your distribution, but it's ok for me with CentOS.
Fix the station name in the file /etc/sysconfig/network :
HOSTNAME=asterisk.yourdomain.net
Add the machine name (HOSTNAME) in /etc/hosts :
127.0.0.1 asterisk.yourdomain.net localhost.localdomain localhost
This must be ok.
Feedback, please.
73,
F6HQZ
Francois
Le 07/01/2010 16:03, Ken a �crit :
from TEST?
Ken
[email protected]
yes I found that item in the QRVC site and as I mentioned , while it works to change the host name within the program; it does not change the hostname to the outside world (DHCP server).
I guess I am now one small step towards guru-hood.
I found this:
etc/sysconfig/network-scripts/ifcfg-eth0
mine looks like this (after I changed the last line from TEST to the name I wanted)
# Broadcom Corporation NetXtreme BCM5701 Gigabit Ethernet
DEVICE=eth0
BOOTPROTO=dhcp
DHCPCLASS=
HWADDR=00:06:5B:F7:28:DF
ONBOOT=yes
DHCP_HOSTNAME=Asterisk1
and - after a reboot - it works. The router now shows the name
so there are two names
     the host name used by the computer internally
     the host name used externally on the network
Ken
27021
-----Original Message-----
To: Ken <[email protected]>
Cc: [email protected]
Sent: Thu, Jan 7, 2010 10:23 am
Subject: Re: [App_rpt-users] host name for DHCP
[root@N8LBV-R ~]#
-Steve
from TEST?
in
Ken
[email protected]
"Always Connected"
(734)527-7150
