We have been running Allstarlink on our repeater for several years. We recently increased our power and have added receive only nodes to fill in the new area. Currently three receive only nodes are running with unique CTCSS tones.
I would like to convert to simple voter and eliminate multiple tones. I configured the repeater and one test node as described in the documentation. I cannot get it to vote. Turning on debug level 8 in Asterisk on both nodes show the RSSI values are being generated on each node. What I don't see is the receive only node sending it's RSSI value over the back channel link. I see both the repeater and receive node key up the repeater at the same time and the audio appears to be from the repeater only. I have compared the RSSI values from each node during the same transmission and the calculated RSSI values vary with distance from the transmit source as expected.
I cannot find in depth documentation on the simple voter protocol other than the one page wiki and there are no searches that show anyone else is having issues. I have double checked that I have done everything required in the configuration (that I know of). Could someone point me at more detailed documentation (I have looked at the source code) or provide trouble shooting tips.
The node is connected half duplex. The audio is good when using the node with a different CTCSS. With simple voter configured it looks like the repeater is not using audio from the the receive node.
If there is something additional to do please let me know.
SOmething here has changed... My voting has always work. I just noticed over the last few days that my touch tones were no longer decoding. I was running the following on the main repeater which has always worked.
votertype = 1
votermode = 2
votermargin = 20
Now I have to comment it out to make tones work unless I enter them from the asterisk CLI, then they work.
I powered up my old node that I retired months ago and fired it up with these setting and connected it to the repeater and it worked as it should. I am not sure when things changed, or even how long ago as I was running the old 2.0 beta.
This voting isn't new to me I was running it on XIapr back many moons ago and had it setup like this as well.
