Help
this is the error I get Im using winscp
I went into preference & disabled the endurance as directed
I am still not able to add info to my rpt.conf
somehow I feel the older system was so much easier
HELP
Help
HELP
I don’t know what WinSCP “endurance” setting is for but I wouldn’t expect it to help permission problems.
When is the error occurring, at logon or when you attempt to edit rpt.conf?
when trying to edit and or modify my conf folders as I need to
to setup the node to be a dmr bridge
it wont allow me to modify any folders etc
Sounds like WinSCP is connecting to the node fine. So you don’t have a port or password issue.
If you are logging in with username repeater you do not have permission to edit any files in /etc/asterisk. You need to login with username root but the root user is not allowed to ssh by default. It is possible to allow root ssh but I’m not sure how folks using WinSCP handle that.
Would any WinSCP users like to shed some light on this?
this should be in the wiki
before connecting to the site on the site list of winscp make sure the protocol used to connect to the node is SCP
If it is not scp click on edit and change it.
Then click on advance
and choose scp/shell on the left pan. and in the shell menu select sudo su -
click OK
save the configuration and reconnect. you will be able to edit every file on the node with winscp
I dont know in the new asl software, setting up the old crompton images root was the norm
so odd this has been changed
Sir, thanks I wil try to access the node now that way
sadly that doesnt work either
I have my root password set to the same as the repeater password though it states access denied
log in with repeater
dont try to log with root from ssh
Le mer. 26 févr. 2020 à 15:20, Mike P via AllStarLink Discussion Groups [email protected] a écrit :
February 26Sir, thanks I wil try to access the node now that way
In Reply To
February 23this should be in the wiki before connecting to the site on the site list of winscp make sure the protocol used to connect to the node is SCP If it is not scp click on edit and change it. [login] Then click on advance [adv] and choose scp/shell on the left pan. and in the shell menu select sud…
ok thanks
than how do I get root access
I assume root is like admin privileges
repeater is like a user
Ill go try that now, thanks
wow
THANKS THAT IS WORKING
now maybe I can finish its etup
the setup I gave you is the same thing as loging with a simple user and escalate the rights of the user to super user with sudo ou su.
SO you keep a safe config on the node that root cant connect on ssh but can still do as a root user with the normal user login.
Le mer. 26 févr. 2020 à 19:59, Mike P via AllStarLink Discussion Groups [email protected] a écrit :
February 27wow
In Reply To
February 26log in with repeater dont try to log with root from ssh Le mer. 26 févr. 2020 à 15:20, Mike P via AllStarLink Discussion Groups [email protected] a écrit : ··· (click for more details)
Yes, thanks
I got some help on the main forum
I have it almost complete
last step is to see if I can add a node radio to the bridge
I cant seem to access simpleusb-tune-menu under sudo -s though
SCP is a PITA!
I don’t use it for that reason.
nano is much better, and does not require special program to work.
So after you ssh into your ASL box,
sudo nano /etc/asterisk/rpt.conf
sudo works usually has a 15 minutes TOT after last use of it.
thanks for the new info
Ok months later I am once again trying to get the bridge working
same PI same IP address, & none of these past setting allow me access
That's because the norm for the SSH daemon configuration item PermitRootLogin is not yes, it's either no (you'll need to authenticate as someone besides root) or without-password (you'll need a SSH private key matching a public one in /root/.ssh/authorized_keys). If you were trying to connect as root, that might explain why you got "access denied."
sudo su - presumes that as whomever you authenticate, be that repeater or any other user, has been set up in sudoers with the NOPASSWD attribute. I don't know if that's the case for the repeater user. Otherwise, sudo would demand entry of that user's password. Ordinarily a SFTP server is only going to ask a password to log in, not for any commands you want to execute once logged in. Maybe this is why you saw the "access denied" in this case.
sudo su - is an idiom that needs to die anyway. What su - does is become (substitute) a user, by default root. - means to initialize the environment/session as if that user had logged in directly. By itself, you'd need to know root's password. What sudo does is slightly different, requiring the calling user 1) to be in the sudoers file, and 2) either a) provide their own password (not root's), or b) have an applicable sudoers entry specify NOPASSWD . sudo already initializes your environment pretty much the same as su -, so there's no need to use that, maybe just the -i argument for an interactive shell (sudo -i). All sudo su - does is make things messier and make people type more.
Yes, something like adding this might fix some access issues, but you also might wreck your system if you're not extremely careful. I had a friend once log into a Xenix286 system as root, and he called me over to ask what /bin/rm: text busy means. Well....he unfortunately accidentally omitted a cd and had entered rm -rf *, thus wiping his whole system. Might be an extreme and rare example, but it's possible.
