Checking configuration:
Info: Skipping evaluation of private node 1878
Info: rpt.conf has configuration for: 687730
Info: /etc/asterisk/iax.conf contains no registration lines.
Info: /etc/asterisk/rpt_http_registrations.conf contains 1 registration line(s)
Info: Registrations present for configured node(s): 687730
Info: IP from https://conntest-east1.allstarlink.org/ip reports: 108.144.12.1
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 108.144.12.1
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 108.144.12.1
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 108.144.15.1
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 108.144.15.1
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 108.144.15.1
OK: HTTP IP probes have consensus on the same perceived IP
OK: IAX IP probes have consensus on the same perceived IP
Testing node 687730:
OK: Node registration config is well-formed
OK: Node registration type is HTTP
OK: register.allstarlink.org is reachable (via HTTP)
OK: HTTP registration state is Registered
OK: Perceived IAX IP:PORT for this node is: 108.144.12.1:4569
OK: Registered to aws-east1a-register1.allstarlink.org - 52.21.169.197
OK: Server-set UDP port matches bindport in iax.conf
OK: Node registration within 10 minutes: 2026-09-10 15:35:24 UTC
Info: Last time IP changed was 2026-09-10 11:56:39 UTC
Warning: Node is not perceived as registered; not tested
Warning: Node 687730 has 1 warning(s)!
Warning: Warnings may or may not be problems depending on configuration
What does the warning mean, what can I infer from it ? This node appears to be registered but will not connect to any other nodes. The number was recently NNXed and it's server was set to 4570.
This node is still in trouble - I re-ran asl-node-auth-check this morning and there appear to be inconsistencies in the IAX port and WAN IP Address (it does not have port forwarding implemented, no incoming connections). 4570 is defined on the Server record and in the node config - but 2 servers are reporting 4569 ? Two different IP addresses ... CGNAT ?
Info: IP from https://conntest-east1.allstarlink.org/ip reports: 107.127.13.30
Info: IP from https://conntest-west1.allstarlink.org/ip reports: 107.127.13.30
Info: IP from https://conntest-west2.allstarlink.org/ip reports: 107.127.13.30
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: 107.120.47.49
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: 107.120.47.49
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: 107.120.47.49
Error: register.allstarlink.org is unreachable (via HTTP)
OK: Perceived IAX IP:PORT for this node is: 107.127.13.30:4570
OK: Node registration within 10 minutes: 2026-09-11 15:43:04 UTC
Info: Last time IP changed was 2026-09-10 23:21:51 UTC
Yes, that's a classic example of Carrier-Grade NAT - your UDP traffic is being handled in a separate network topology from HTTP/Web traffic. Try IAX registration to see if it helps, but you likely want to move to 44Net Connect.
Info: IP from udp://conntest-east1.allstarlink.org:4570 reports: ...
Info: IP from udp://conntest-west1.allstarlink.org:4569 reports: ...
Info: IP from udp://conntest-west2.allstarlink.org:4569 reports: ...
If so, the :4570 and :4569 references are the port #'s of our test servers.
