When users are talking I’m hear the audio sound on the node with some kind of noise
With that limited info,
I can only give you 2 most popular possibilities.
You are generating a PL tone or passing a PL tone that is not filtered on the output.
You have RF on your audio lines.
I’m don’t know what it is but when I’m hearing a station and I’m belive there hear it there side when I’m talking it sounds like a pl tone is ot any fix on this that if it is this issue though if we can fix a pl tone and if its not that we can look more in to it how’s that sound do you need look at the config file? If u do please let me know what file you need please
I’m have done a audio file but it’s not in mp3 and will not let me post it
Well it would not hurt to see your
simpleusb.conf or your usbradio.conf depending on which channel driver you are using.
You might try to send the mp3 as a personal message to me and if that works, I will post it for others to hear if it is not obvious to me.
; simple usb configration added by simpleusb-config.sh
; 2023.10.20.2146
[general]
[usb]
; Generic Default Settings
eeprom=1
; 1 = Indicates that an EEPROM internal to the radio
; adapter and cable is expected.
; 0 = no warning message if no EEPROM found.
rxboost=1
; Rx Audio Boost
; 0 = 20db attenuator inserted
; 1 = 20db attenuator removed
; Set to 1 for additonal gain if using a low-level
; receiver output.
txboost=1
txboost=0 ; 20 dB pad inserted in audio stream to transmitter (=1, no pad)w
carrierfrom=usb
; Options - no,usb,usbinvert
; usb - via USB radio adapter COR connection
; usbinvert - same as above but inverted polarity.
ctcssfrom=usb
; CTCSS Decoder Source
; Options = no,usb,dsp
; usb - CTCSS decoding using input from USB adapter
invertptt=1
; Invert PTT 0 = ground to transmit, 1 = open to
; transmit
; This is the collector lead of the 2n4401 on the
; modified usb sound fob.
plfilter=yes
; enable PL filter
; yes, enabled
; no, disabled
deemphasis=yes
; enable de-emphasis (input from discriminator)
; yes, enabled
; no, disabled
preemphasis=yes
; enable pre-emphasis (output to Tx)
; yes, enabled
; no, disabled
rxaudiodelay=0
; default value is 0
; rx audio delay for squelch tail elimination.
; Squelch tail delay in 20ms frames. Values range
; from 0 (no delay) to 24 (480ms delay)
; Typical values would range from 5-10 (100-200ms)
; Uncomment and configure following lines for second USB node
;[usb1]
;eeprom=0
;rxboost=1
; 0 = 20db attenuator inserted, 1= 20db attenuator removed
; receiver output
;carrierfrom=usbinvert
; no,usb,usbinvert
; usb - from the COR line on the modified USB sound fob
; usbinvert - from the inverted COR line on the
; modified USB sound fob
;ctcssfrom=no
; no,usb,usbinvert
; usb - CTCSS decoding using input from USB FOB
; usbinvert - from the inverted CTCSS line on the
;invertptt=0
; Invert PTT 0 = ground to transmit, 1 = open to transmit
; This is the collector lead of the 2n4401 on the modified
; usb sound fob.
; please refer to the howto for the procedure to do this.
plfilter=yes
dcsfilter = no
rxondelay = 0
queuesize = 8
tx_audio_level_method = 0
; enable PL filter
; Only uncomment following two lines if necessary for your installation
;deemphasis=yes
;preemphasis=yes
; enable pre-emphasis (output to TX)
;rxaudiodelay=0
; EOF
Mike can you pm me please as I’m can’t find the message button on here sorry
Hi all
I’m I missing something on the confi also how can I get the rf of my audio lines please
Look on the top right with your icon -click
