Help please Connection Failed
Help please I have constructed a radioless node Pi3B ASL3 which appears to work perfectly. I can connect to and use Hubnet or parrot servers, however when trying to connect to virtually any other node results in “Connection Failed”.
This occurs either with Supermon or DTFM mic.
John Knott 2E0KNJ Node 62336
Please provide relevant console/log output from Asterisk/app_rpt so we can help troubleshoot.
Power up node, with Allmon connect 55553 (parrot) sucess, 2296 (local repeater) fail, to try to generate error report.
AS per basic trouble shootig tips using cockpit terminal
asl@node62336:~ $ journalctl -xeu Asterisk/App_Rpt
Invalid unit name “Asterisk/App_Rpt” escaped as “Asterisk-App_Rpt” (maybe you should use systemd-escape?).
Furthur advice please.
John Knott 2E0KNJ
Open the asterisk console with asterisk -rvvvvv and then try your link command. Copy/paste output.
Sorted thank you my password was incorrectly entered, corrected by editing node settings, now shown as connected and successfully accessed East Coast Reflector
Please close topic
