Help on using CTCSS with usbradio.conf
To Whom It May Concern,
I am trying to get a DMK URIx working with a BridgeCOM repeater using the usbradio.conf to provide CTCSS decode/encode and am having no success.
I can confirm that a received FM signals get repeated, and the allstar configuration also appears to be working. However any configuration related to CTCSS does not work at all.
I can confirm that the CTCSS tone is present with the input audio being fed to the URIx, but none of the relevant settings in usbradio.conf(e.g. rxctcssfreqs, ctcssfrom = dsp) seem to have any effect.
Adjusting the carrierfrom parameter in usbradio.conf has the expected results. The COR signal comes to the URIx from the repeater and functions correctly with carrierfrom set to usbinvert. At least with this I can confirm that apt_rpt is using usbradio.conf rather than simpleusb.conf.
While I have tested the hardware, I have not tried looking at the software beyond glancing through the source code to get a rough idea of the layout of apt_rpt.
Could anyone offer a working configuration example on CTCSS, or perhaps give debugging hints?
I can handle a debugger but am not sure of a good way to debug a program that operates on signals in real time.
Thanks in advance,
Neil
See if this helps:
txctcssdefault = 123.0 ; default tx ctcss freq, any frequency permitted
rxctcssfreqs = 123.0 ; rx ctcss freqs in floating point. must be in table
txctcssfreqs = 123.0 ; tx ctcss freqs, any frequency permitted
; rxctcssoverride = 0 ; Set to 1 or yes to start out in carrier squelch mode
carrierfrom = dsp ; no,usb,usbinvert,dsp,vox
; usb - from the COR line on the modified USB sound fob
; usbinvert - from the inverted COR line on the modified USB sound fob
; dsp - from RX noise using dsp techniques
; vox - voice activated from RX audio
ctcssfrom = dsp ; no,usb,dsp
; usb - CTCSS decoding using input from USB FOB
; (currently not supported)
; dsp - CTCSS decoding using RX audio in DSP.
; rxdemod option must be set to flat for this to work.
rxdemod = flat ; input type from radio: no,speaker,flat
; flat - Use RX audio from discriminator (before de-emphasis)
txprelim = yes ; Audio processing on left output channel: no,yes
; no - Audio is not pre-emphasized and limited.
; Suitable for use on a microphone input
; yes - Audio is pre-emphasized and limited.
; Suitable for direct connection to an FM modulator
txlimonly = no ; Audio limiting with no pre-emphasis on output channel: no,yes
; no - Audio is not limited.
; yes - Audio is limited.
; Suitable for transmitters with no limiting but with pre-emphasis.
txtoctype = phase ; Transmit tone control type: no,phase,notone
; phase - encode CTCSS and reverse phase
; AKA ("reverse burst") before unkeying TX
; notone - encode CTCSS and stop sending tone before unkeying TX
; AKA ("chicken burst")
txmixa = no ; Left channel output: no,voice,tone,composite,auxvoice
; no - Do not output anything
; voice - output voice only
; tone - CTCSS tone only
; composite - voice and tone
; auxvoice - auxiliary voice output at headphone level for monitoring
txmixb = composite ; Right channel output: no,voice,tone,composite, auxvoice
; See txmixa above.
Thanks in advance,
Neil
Neil
We have a Bridgecom 220 repeater hooked to an RLC-DSP404. Guidance regarding connectivity can be gained from -
https://cdn.shopify.com/s/files/1/0833/9095/files/BCR_to_RLC_Pinout_Diagram_b06dbd28-8f77-439b-9a74-3adc552f93a3.pdf?9343440214198702669
Between these two documents, you should be able to connect things together.
Keith
On Oct 22, 2017, at 9:47 PM, Steve Zingman <szingman@msgstor.com> wrote:
See if this helps:
            ; See txmixa above.
Thanks in advance,
Neil
I apologize for the long delay. Family life got in the way for a bit, and then I thought to check and double-check that I had implemented your suggestions faithfully. This was the usual "Because I waited so long I have to do better" type of paralysis.
Thank you Keith for the pinouts between the URIx and the BCR-40U. I have to wonder if suboptimal audio level settings might cause my issues. I don't suppose that you have those audio levels documented. I would expect that the levels would be nearly identical between any URIx+BCR combination.
Thank you for the suggestion Steve. I implemented your usbradio.conf then made single adjustments until I could get something to happen.
For the moment, I can confirm that I do get a working CTCSS encoding. At least it is enough to open the squelch on a test radio.
For receive tests, my test criteria is watching to see the red tx light on the URIx or listening to the signal via the allstar node.
I have txmixa set to composite as I am connected to the left audio channel of the URIx.
carrierfrom = dsp does not appear to work for me. I have to leave this set on usbinvert for anything to work.
If the 'rxctcssoverride' parameter is set to '0' or commented, I can never open the squelch. So I have to leave this as '1'.
ctcssfrom = dsp does not appear to do anything. Even in this setting, any signal without CTCSS gets repeated.
I left the other settings identical.
On 10/23/2017 09:55 AM, Keith Goobie wrote:
Neil
https://cdn.shopify.com/s/files/1/0833/9095/files/BCR_Repeater_to_URI.pdf?7576387813378094434
Keith
See if this helps:
             ; See txmixa above.
Thanks in advance,
Neil
I know this is an old thread but thought I’d give it a try anyway. I’m having what seems to be the same issue. Interfacing allstar controller with a Yaesu DR1x repeater. Everything else seems to work pretty good, even the CTCSS encoding is working, but I cannot get it to decode CTCSS. If I set rxctcssoverride to 0 I can’t get the squelch to open. With it set to 1 it opens fine but any signal on Rx frequency will open it even without a tone programmed in the radio. Any further ideas or fixes would be appreciated.
Can you post your usbradio.conf
usb.conf is listed below. I removed my actual node number and replaced it with “NODE”
; If you are going to use this channel driver, you MUST enable it in modules.conf
; noload => chan_usbradio.so ; CM1xx USB Cards with Radio Interface Channel Driver (DSP)
; to:
; load => chan_usbradio.so ; CM1xx USB Cards with Radio Interface Channel Driver (DSP)
; Usbradio channel driver Configuration File
[general]
[usb_NODE]
; 0 = no (default)
; 1 = yes
hdwtype = 0 ; Leave this set to 0 for USB sound fobs modified using
rxboost = 1 ; 0 - 20db attenuator inserted
; 1 - 20db attenuator removed
; Set to 1 for additonal gain if using a low-level receiver output
rxctcssrelax = 1 ; reduce talkoff from radios w/o CTCSS TX HPF
rxsqhyst = 3000 ; Setting Squelch Hysteresis
; 3000 is the default amount.
; An amount of 500 seems good.
; Then set the squelch to the highest number revealed when doing a “radio
; tune rxsquelch” - running the command multiple (like 20) times in a row.
; http://allstarnode.com/wiki/lib/exe/fetch.php?media=asterisk-notes-wj8g.pdf
txctcssdefault = 77.0 ; default TX CTCSS frequency, any frequency permitted
rxctcssfreqs = 77.0 ; RX CTCSS frequencies list in floating point. must be in table
txctcssfreqs = 77.0 ; TX CTCSS frequencies list. any frequency permitted. will follow RX CTCSS frequency
rxctcssoverride = 1 ; Set to 1 to start out in carrier squelch mode
carrierfrom = usbinvert ; no,usb,usbinvert,dsp,vox
; usb - from the COR line on the USB sound fob (Active high)
; usbinvert - from the inverted COR line on the USB sound fob (Active low)
; dsp - from RX noise using DSP techniques
ctcssfrom = dsp ; no,usb,usbinvert,dsp
; no - no CTCSS decoding, system will be carrier squelch
; usb - from the CTCSS line on the USB sound fob (Active high)
; usbinvert - from the inverted CTCSS line on the USB sound fob (Active low)
rxdemod = speaker ; input type from radio: no,speaker,flat
rxsquelchdelay = 20 ; delayline in ms carrier squelch tail eliminator
rxondelay = 0 ; Number of 20mSec intervals following the release of PTT.
; Uncomment and/or adjust for simplex nodes to eliminate “Ping Ponging”
; or “Relay Racing”. A positive value here will instruct the usbradio
; driver to ignore the COR line for a specified number of 20mSec
; intervals following the release of PTT. Use this ONLY on simplex
; nodes, and leave commented out for repeaters or other full duplex nodes.
txboost = 1 ; Add transmitter audio gain boost: 0,1
txtoctype = notone ; Transmit tone control type: no,phase,notone
; AKA (“reverse burst”) before unkeying TX
; AKA (“chicken burst”)
txmixa = composite ; Left channel output: no,voice,tone,composite,auxvoice
; Audio filters - requires version newer than ASL_1.01
rxlpf = 0 ; Receiver Audio Low Pass Filter 0,1 2
; 0 - 3.0 kHz cutoff (Default) value for reduced noise and increased intelligibility.
; 1 - 3.3 kHz cutoff for increased high end, sibilance and brightness.
; 2 - 3.5 kHz cutoff for even more high end, sibilance and brightness.
rxhpf = 0 ; Receiver Audio High Pass Filter 0,1
; 0 - 300 Hz cutoff. (Default) value to reduce sub-audible signals for retransmission and in the receiver speaker.
; 1 - 250 Hz cutoff for additional received and retransmitted bass response.
; recommend using this filter with a CTCSS tone no higher than 186.2 Hz.
txlpf = 0 ; Transmitter Audio Low Pass Filter 0,1
; 0 - 3.0 kHz cutoff. (Default) value.
txhpf = 0 ; Transmitter Audio High Pass Filter 0,1,2
; 0 - 300 Hz cutoff. (Default) value to reduce interference between voice and sub-audible signaling tones and codes.
; 1 - 250 Hz cutoff for increased bass response in transmitted audio.
; 2 - 120 Hz cutoff for special applications requiring additional bass response in transmitted audio.
; Not recommended due to the increased possibility of voice energy interfering with sub-audible signaling
invertptt = 0 ; Invert PTT: 0,1
; 0 - ground to transmit
; 1 - open to transmit
duplex = 1 ; Duplex 0,1
; 0 - half duplex
; 1 - full duplex
duplex3 = 0 ; duplex 3 gain setting (0 to disable) ???
#includeifexists custom/usbradio.conf
There can be many reasons for what you are experiencing.
Hard for me to pick one path.
The first one would be if the repeater radio rx is ‘pl filtering’ on audio output or allowed to pass.
So, I might also ask the duplex mode in rpt.conf for this node.
And know that audio levels have to be pretty close for ctcss to function correctly.
Duplex mode is set to duplex = 2
I suppose it’s possible that it’s an audio problem, you’re guess is probably better than mine for sure haha. I will say though that audio levels on the system seem to be pretty great for both rx and tx audio. The tx PL tone is working fine but no dice on rx tones. I think it may be a good guess that the receiver on the repeater isn’t passing the tone…however, I’m not sure how or if it’s even possible to get it to.
While I am not familiar with that repeater, most modern systems have a programmability to that end.
and
Just because the output audio seems correct, does not mean the input level is correct.
It could be low and you can make that up on the output side. or v v
But normally low rx amplitude is the issue, especially if you hear no distortion in voice…
I can only give you some ideas to check.But I would rule those 2 out before doing much. Except perhaps with audio levels
I did a little checking and might suggest, ‘only if you find nothing’, to use discriminator audio for that unit,
then pre and de-emphasis on in simpleusb.conf
You are only running this looking for a tone with ‘analog audio’ ?
I am using USBradio driver and not simpleUSB…was that just a mistake on your end? I didn’t think simpleUSB had the ability to encode/decode ctcss or any DSP options for that matter.
I may have too low of audio…but in the radio tune menu Rx audio seems to have good deviation and it seems to be hearing me just fine. It does have really low rx audio though and I had to turn the audio gain pot (on my soundcard…DBA-30) up to pretty much max if I remember correctly. I also have rxboost turned on and my rx audio level on the usb tune menu is set to 999.
Below is from the manual of the repeater…maybe i should try using pin 8 instead of 9 for my rx audio feed…
