Hello Allstar Community
My name is Mats and my call is sa2awo from north sweden…A friend build a nod to me Everything is workning good… I like have more power out so i put my IC-2820 who crossband… Working good but when i releases the PTT so i get a noise tail few seconds also the other releases the PTT get also a noise tail. I have check everything in to the radio the noise tail.is left… Someone have a ide ?
73 de sa2awo
Mats,
While it may be difficult for you to do,
Can you post a audio clip of the event.
Hearing is believing and it may help identify what it is from more experienced ears.
If the board will not let you attach for being a new user, send it to me as a personal message and I will post it for all to hear.
But I will add you need to trace this in some form to know if it comes from the rx side or the tx side to get closer to a solution.
But I do hope you are not referring to a normal static crash from a slow closing squelch gate on the rx.
I send a email to u …I get your email from QRZ.com
73 de sa2awo
