Hamtronics receiver issue with AllStar RTCM
For a voter project, we got the hamtronics VHF receiver pretuned to the repeaters input frequency. The idea is to use hamtronics receivers for every voted receive site for equivalent audio characteristics.
http://www.hamtronics.com/r303.htm
When hooked up to the discriminator on the hamtronics board, I could not get the RTCM to calibrate squelch. It usually told me the audio was too low weather the RX level was bumped up or down. I then hooked it up to a motorola SM50 and it calibrated shortly after adjusting RX levels.
So… I hooked a cheap sound card up to audacity, and took a look at the spectrum of each receiver. The hamtronics obviously looks like it lacks high frequency noise on the discriminator output.
Here is the SM50 discriminator out:
amsatnet.info/SM50.png
Here is the hamtronics discriminator out:
amsatnet.info/HAMTRONICS.png
Here is an audio sample comparing them (you can probably guess which radio is first):
amsatnet.info/Sm50_hamtron_DISC.wav
Does anybody else have experience with hamtronics receivers?
Skyler KD0WHB
Try adding JP1 in the RTCM. This gives some gain to the squelch noise amp.
If that works you’ll want to turn on the RTCM’s BEW (#17 on the main menu). If it’s not on that menu you’ll need to download the proper firmware and upgrade. This help radios with low out of band discriminator noise not false the squelch on voice peaks. There 3 settings 0) off, 1) on, and 3) on with more aggressive locking.
But first make sure you can calibrate the squelch with JP1 in. Otherwise your SOL and there’s no reason to upgrade. In that case you’ll have to buy some other radios for your voters.
Skyler KD0WHB
Tim
Ok, so JP1 is just for the squelch amp? the RX levels are fine. When I ignored squelch, I could easily get a 3khz tone to show at 3khz on the menu.
Skyler KD0WHB
Tim
Skyler Fennell
amsatnet.info
KDØWHB
Honestly…With $25 Maxtracs all over the place…why…WHY would you want to screw around with anything Hamtronics makes…seriously…
Skyler KD0WHB
Tim
Because the Denver Radio club wants to
Skyler KD0WHB
Tim
Skyler Fennell
amsatnet.info
KDØWHB
Yes, I have a number of them in place and find they work perfectly with the
RTCM. It can give about 2v P-P on the discriminator pin, and has the high
frequency compute the RTCM squelch needs.
My prime setup is here:
Note you'll want to put a cap in line, as the discriminator is DC coupled in
the hamtronics. Can you put a scope on the discriminator line and measure the
voltage? You might have a problem with the receiver.
73's
So... I hooked a cheap sound card up to audacity, and took a look at the
Bryan Fields
727-409-1194 - Voice
727-214-2508 - Fax
http://bryanfields.net
My scope does not really work very well anymore but I’ll see if I can get a P-P reading. What value cap should I put on the discriminator line?
http://gallery.keekles.org/d/28384-2/0330141929a.jpg
Note you’ll want to put a cap in line, as the discriminator is DC coupled in
73’s
Bryan Fields
727-214-2508 - Fax
Skyler Fennell
amsatnet.info
KDØWHB
I am getting 2v P-P
73’s
Bryan Fields
727-214-2508 - Fax
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Hi Bryan, can you send me the exact wiring between your hamtronics and your RTCM? What value DC blocking capacitor, any jumpers in the RTCM selected etc…?
73,
Skyler
73’s
Bryan Fields
727-214-2508 - Fax
Skyler Fennell
amsatnet.info
KDØWHB
I added a 10µF electrolytic capacitor in series with the Discriminator output of my hamtronics, but was still not able to get the squelch calibrated. Here was the diagnostic output:
Testing level at 1000 Hz for De-Emphasized Audio
Testing level at 2000 Hz for De-Emphasized Audio
Error – Measured 9581, should have been between 4380 and 6155
Testing level at 3200 Hz for De-Emphasized Audio
Error – Measured 10030, should have been between 2271 and 3073
Testing level at 3200 Hz for Squelch Noise Detector
Error – Measured 279, should have been between 0 and 50
Testing level at 6000 Hz for Squelch Noise Detector
Testing level at 7200 Hz for Squelch Noise Detector
Error – Measured 211, should have been between 500 and 1023
On Sun, Mar 27, 2016 at 10:53 PM, Eric Guth eric@efratnetworks.net wrote:
10 Uf , 35VDC will usually do the job.
73,
Eric Guth
4Z1UG
Allstar: 28422
QSO Today
From: app_rpt-users-bounces@ohnosec.org [mailto:app_rpt-users-bounces@ohnosec.org]
On Behalf Of Skyler F
Sent: Monday, March 28, 2016 7:35 AM
To: Bryan Fields
Cc: app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] Hamtronics receiver issue with AllStar RTCM
73,
Skyler
73’s
Bryan Fields
727-214-2508 - Fax
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Actually, the normal audio output is probably what is needed, not de-emph. Again with the 10µF capacitor.
Here is my entire output when I get Normal Audio as good as I can get it. Everything passes except for 3200Hz.
Testing level at 100 Hz for Normal Audio
Testing level at 320 Hz for Normal Audio
Testing level at 500 Hz for Normal Audio
Testing level at 1000 Hz for Normal Audio
Testing level at 2000 Hz for Normal Audio
Testing level at 3200 Hz for Normal Audio
Error – Measured 10755, should have been between 6929 and 9374
Testing level at 100 Hz for CTCSS Filtered Audio
Error – Measured 11719, should have been between 100 and 451
Testing level at 320 Hz for CTCSS Filtered Audio
Testing level at 500 Hz for CTCSS Filtered Audio
Testing level at 1000 Hz for CTCSS Filtered Audio
Testing level at 2000 Hz for CTCSS Filtered Audio
Error – Measured 12326, should have been between 8989 and 12162
Testing level at 3200 Hz for CTCSS Filtered Audio
Error – Measured 11827, should have been between 6929 and 9374
Error – Measured 45868, should have been between 9798 and 13257
Error – Measured 41568, should have been between 4380 and 6155
Error – Measured 43439, should have been between 2271 and 3073
Error – Measured 436, should have been between 0 and 50
Error – Measured 264, should have been between 500 and 1023
73,
Eric Guth
4Z1UG
Allstar: 28422
QSO Today
To: Bryan Fields
73,
Skyler
73’s
Bryan Fields
727-214-2508 - Fax
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Here is the schematic of the hamtronics output:
amsatnet.info/r303out.png
Isn’t R34 and C44 a lowpass??
On Mon, Mar 28, 2016 at 11:51 AM, Skyler F electricity440@gmail.com wrote:
I think normal would be disc., the only other display is deemphasized and CTCSS filtered
On Mon, Mar 28, 2016 at 11:36 AM, Steve Agee n5zua@earthlink.net wrote:
` For this exercise, audio is either referenced as pre-emphasized
(discriminator) or de-emphasized (speaker). So, by “normal” do
you mean discriminator?
    N5ZUA
Normal Audio
Normal Audio
Normal Audio
Normal Audio
Normal Audio
Normal Audio
            Error -- Measured 10755, should
Filtered Audio
            Error -- Measured 11719, should
Filtered Audio
Filtered Audio
            Error -- Measured 12326, should
            Error -- Measured 11827, should
De-Emphasized Audio
            Error -- Measured 45868, should
De-Emphasized Audio
            Error -- Measured 41568, should
De-Emphasized Audio
            Error -- Measured 43439, should
            Error -- Measured 436, should
            Error -- Measured 264, should
Skyler Fennell
amsatnet.info
KDØWHB
Audio
Audio
                Error -- Measured 9581, should have been
Audio
                Error -- Measured 10030, should have been
Detector
                Error -- Measured 279, should have been between
0 and 50
Detector
Detector
                Error -- Measured 211, should have been between
500 and 1023
Skyler Fennell
amsatnet.info
KDØWHB
wrote:
                          10
                        73,
                          Eric
Guth
4Z1UG
                          Allstar:
28422
QSO
Today
[mailto:app_rpt-users-bounces@ohnosec.org ]
AM
To: Bryan Fields
RTCM
                              Hi Bryan, can you
73,
Skyler
                                On Sun, Mar 27,
2016 at 5:08 PM, Bryan Fields <Bryan@bryanfields.net >
wrote:
                                On 3/27/16 5:12
the
for
at the
lacks
receivers?
with the
high
needs.
                                [http://gallery.keekles.org/d/28384-2/0330141929a.jpg](http://gallery.keekles.org/d/28384-2/0330141929a.jpg)
coupled in
measure the
with the receiver.
                                73's
                                  Bryan Fields
                                  727-409-1194                                         -
Voice
                                  727-214-2508                                         -
Fax
                                  [http://bryanfields.net](http://bryanfields.net)
please visit
options button”
                                    You do not need a password to
unsubscribe, you can do it via
email confirmation. If you have
trouble unsubscribing, please
send a message to the list
detailing the problem.
                                    Skyler
Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
<snip>
Strange, are you 100% sure you're on the discriminator output?
From what you have it looks like you're on the lowpass filtered and amp'd
speaker output.
On 3/28/16 1:22 PM, Skyler F wrote:
Bryan Fields
727-214-2508 - Fax
Skyler;
1) Make sure the receiver First Local Oscillator is adjusted
correctly on frequency. (Fo -10.700 MHz) Likewise the second LO
should be at around 10.2450 MHz. The second LO is not adjustable, so
any minor error would have to be made up with the TCXO U3. After
this second step:
Then :
2) Make sure the general alignment is set properly, especially the
discriminator coil T2 which responds to 10.7000 MHz from a signal
generator, has an S curve response.� In my experience with these
sort of Quadrature� Detector chips, you can get a false sense of IF
centering where the noise component is suppressed. You might try
adjusting for maximum noise first without the 10.7000 MHz signal. Be
careful you don’t jam the coil slug.
Joe Leikhim
On 3/27/2016 7:48 PM, Skyler F wrote:
I am getting 2v P-P
PM, Bryan Fields <>
wrote:
                    On
output.
                  RTCM.� It can give about 2v P-P on the
                  the hamtronics.� Can you put a scope on the
                  voltage?� You might have a problem with the
receiver.
                  73's
                      Bryan Fields
                      727-409-1194�- Voice
                      727-214-2508�- Fax
                      To unsubscribe from this list please visit [](http://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users)
You do not need a password to unsubscribe, you
can do it via email confirmation. If you have
trouble unsubscribing, please send a message
to the list detailing the problem.
Skyler Fennell
amsatnet.info
KD�WHB
Skyler Fennell
amsatnet.info
KD�WHB
-- Joe Leikhim
Leikhim and Associates
Communications Consultants
Oviedo, Florida
407-982-0446
Bryan@bryanfields.nethttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-users
electricity440@gmail.comApp_rpt-users@ohnosec.orghttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usershttp://ohnosec.org/cgi-bin/mailman/listinfo/app_rpt-usersJLeikhim@Leikhim.comWWW.LEIKHIM.COM
Isn't R34 and C44 a lowpass??
I don't know what to make of your calibration errors as they don't seem to
correlate to a HF roll-off problem, but to answer your question, yes, it's
an RC low-pass filter, with a -3 dB corner at 2.4 kHz. You might want to
replace the 0.033 uF shunt cap with 0.01 uF to flatten out the high end of
the audio passband a bit.
        --- Jeff WN3A
This email has been checked for viruses by Avast antivirus software.
Replying to myself...
After finding a better scan of the receiver schematic, what I thought was a
2k resistor as R34 is really 1k, so the corner is 4.8 kHz. Based on that, I
doubt even more the HF roll-off is the reason your calibration is failing.
          --- Jeff WN3A
These are both very good points i didn't consider. I normally don't check my
reference oscillators in the hamtronics as they are using an external 10MHz
source.
You will want to check SINAD on it as well, if it's not making spec (and those
hamtronics are very sensitive), something else is wrong with it.
On 3/28/16 2:51 PM, Joe Leikhim wrote:
1) Make sure the receiver First Local Oscillator is adjusted correctly
on frequency. (Fo -10.700 MHz) Likewise the second LO should be at
around 10.2450 MHz. The second LO is not adjustable, so any minor error
would have to be made up with the TCXO U3. After this second step:
Then :
generator, has an S curve response. In my experience with these sort of
Quadrature Detector chips, you can get a false sense of IF centering
where the noise component is suppressed. You might try adjusting for
maximum noise first without the 10.7000 MHz signal. Be careful you don't
jam the coil slug.
Bryan Fields
727-214-2508 - Fax
If you are using an external reference, you cannot make up for the 2nd LO error if it is wildly off. There is an easy SINAD related test in EIA-603 that is called Offset Acceptance Bandwidth that would indicate if the IF were off center. Things that could go wrong apart from simple misalignment of the Quad Detector coil could include the LO crystal being way off frequency, the IF filters being wrong BW or off spec pass frequency.
Given the symptoms, I am putting my money on a misadjusted quad coil.
Joe
Then :
jam the coil slug.
source.
Joe Leikhim
Oviedo, Florida
407-982-0446
WWW.LEIKHIM.COM
I don’t have the test equipment to go through all of the dirty Local Oscilator, SINAD, etc., so I will have to wait on that a few weeks before the president of the club gets back in town.
WHEN I bypassed the capacitor and resistor ( 1k and .03µ) , the RTCM was able to calibrate squelch. The LED flashed several times and then was steady. Maybe the capacitor is the wrong value. There was no code on it, but based on the resistor code, the value was correct.
Skyler
  1. Make sure the receiver First Local Oscillator is adjusted correctly
Then :
  1. Make sure the general alignment is set properly, especially the
maximum noise first without the 10.7000 MHz signal. Be careful you don’t
jam the coil slug.
These are both very good points i didn’t consider. I normally don’t check my
source.
You will want to check SINAD on it as well, if it’s not making spec (and those
Joe
Joe Leikhim
Oviedo, Florida
407-982-0446
WWW.LEIKHIM.COM
Skyler Fennell
amsatnet.info
KDØWHB
Were these receivers factory built and tuned or did individual club
members build them? Either way, you might try others from the lot.
If you have only a rudimentary signal generator and / or frequency
counter, perhaps I can walk you through some “field expedient” steps
over the phone.
On 3/30/2016 12:01 PM, Skyler F wrote:
    I don't have the test equipment to go through all
back in town.
Skyler
adjusted correctly
should be at
so any minor error
second step:
              Then :
especially the
from a signal
with these sort of
of IF centering
adjusting for
careful you don’t
              jam the coil slug.
            source.
with it.
        If you are
frequency.
quad coil.
            Joe
          Joe Leikhim
          Oviedo, Florida
button”
You do not need a password to unsubscribe, you can do it
via email confirmation. If you have trouble
unsubscribing, please send a message to the list
Skyler Fennell
amsatnet.info
KDØWHB
-- Joe Leikhim
Oviedo, Florida
407-982-0446
407-982-0446
WWW.LEIKHIM.COM
electricity440@gmail.comJLeikhim@Leikhim.comWWW.LEIKHIM.COM
