I am in the middle of trying to figure out how the installation of allstar can be put on anyone of the following distros that are available to me in my VPS
Debian 7 Preferred install if possible
Centos 7
Ubuntu 14.04LTS
Ubuntu 14.10
I have tried many different methods including replacing zaptel with Dahdi not sure i did things right or not but still no luck with the installation here is what I found out so far my Linode has custom Kernal headers this is very bad for any type of installation like this so here is the tutorial i found to change the linux headers.
https://www.linode.com/docs/tools-reference/custom-kernels-distros/run-a-distributionsupplied-kernel-with-pvgrub#debian-7-wheezy
My current installation is Debian 7 But i have tried all of the above listed distributions with no success…
So here so far is my command line step by step on this machine roughly
First step was to change Linux Headers to generic headers
apt-get update
1. ```
apt-get upgrade --show-upgraded
apt-get install linux-image-amd64
1. ```
mkdir /boot/grub
apt-get install grub-legacy
1. ```
grub-set-default 1 (Generates /boot/grub/menu.lst )
update-grub
1. nano /boot/grub/menu.lst Edited some timer to 10 and updated kopt=
kopt=root=/dev/xvda console=hvc0 ro quiet Double check groot=(hd0)
1. ```
update-grub
- In the Linode Manager, edit your Linode’s configuration profile to use either pv-grub-x86_32 or pv-grub-x86_64 as the kernel, depending on the version of Debian you have deployed (32-bit or 64-bit). (My host only offers x86_64
- reboot from dashboard after adjusting some minor settings in the profile.
- In Console uname -a
- Response from uname -a Linux (none) 3.2.0-4-amd64 #1 SMP Debian 3.2.65-1+deb7u2 x86_64 GNU/Linux
Ok now we first installed asterisk just regular using
apt-get install asterisk-dahdi
Not exactly sure what it did things at this point have now become sketchy because i am unsure where the config files for allstar should be also i am use to the centos based acid and so I think i am getting confused some where in the installation but here is my history so far on this machine…
1 apt-get update
2 apt-cache search dahdi
3 apt-get install asterisk-dahdi
4 cd /tmp
5 wget http://dl.allstarlink.org/installcd/zsync-0.6.1.tar.bz2
6 tar -jxvf zsync-0.6.1.tar.bz2
7 cd zsync-0.6.1
8 ./configure
9 make
10 make install
11 cd /etc/init.d
12 wget http://dl.allstarlink.org/installcd/rc.updatenodelist
13 mv rc.updatenodelist updatenodelist
14 chmod 755 updatenodelist
15 ./updatenodelist &
16 nano /etc/init.d/asterisk
17 ./updatenodelist &
18 ./asterisk start
19 nano /etc/init.d/asterisk
20 ./asterisk start
21 ./asterisk restart
22 ./updatenodelist &
23 ./asterisk restart
24 ./updatenodelist &
25 ls
26 cd /etc/asterisk
27 nano rpt.conf
28 nodesetup.sh
29 ls
30 nano /var/lib/asterisk/keys/allstar.pub
31 clear
32 apt-get install
33 apt-get install curl
34 cd /usr/src
35 wget http://x.allstarlink.org/svn-trunk.tar.gz -O- | tar xzv
36 mv trunk astsrc
37 cd astsrc
38 make upgrade-acid
39 menuselect.makeopts
40 service asterisk restart
41 cd …
42 apt-get install git-core
43 git clone https://github.com/KD8EYF/squeezeterisk.git
44 ./squeezeterisk/scripts/allstar-install.sh
45 apt-get update
46 apt-get upgrade --show-upgraded
47 apt-get install linux-image-amd64
48 mkdir /boot/grub
49 apt-get install grub-legacy
50 grub-set-default 1
51 update-grub
52 nano /boot/grub/menu.lst
53 nano /boot/grub/menu.lst
54 update-grub
55 history
Loren Tedford (KC9ZHV)
Email: lorentedford@gmail.com
Email: lorentedford@live.com
Email: lorentedford@aol.com
Email: LorenCS@Ltcraft.net
Email: lorentedford@yahoo.com
Email: loren@lorentedford.com
Email: loren@richlandcountycomputers.com
Email: loren@newwavesucks.com
Phone:
http://www.richlandcountycomputers.com
