Hi guys,
I’ve sort of been documenting my progress setting this node up through various questions already asked here (see [Motorola RICK (HLN3333B) and RPi interface] and [GR300 Repeater No TX Audio]). So far, I’ve tested my GR300 and it’s working perfectly, but I usually have it hooked up with the RICK (HLN3333B). The RICK acts to power on the TX radio in this configuration (i.e. if I do not have the RICK hooked up, when I turn the repeater on only the RX radio comes on).
My current setup is:
Raspberry Pi 4 running latest version of HamVoip Allstar image.
RIM-Maxtrac-RM wired into both radios and via USB to the rPi
The RIM does not seem to be providing the power on function to the TX radio as the RICK normally does… Do I need to set some specific settings in the Allstar config files? Or am I going to have to dig a little deeper and make mods/set jumpers on the radio itself? I have read just about every “begginer guide” and “how to” on the Allstar Wiki… Can’t seem to find anyone actually using this setup with any in-depth guide… I also can’t seem to find any info on the RIM-Maxtrac LED meanings… Is there some sort of manual page for that?
Many thanks
