good connection to URI?
Hi guys…
ast week i did a harness to hook my tkr-750 ver 2 to a URI
here is what I did:
tkr-750 pin ----- uri
8 to 22 (ctcss tone to tkr)
9 to 26 (voice to tkr)
10 to 21 (audio to uri)
12 to 19 (ground)
16 to 1 (ptt)
17 to 8 (cor)
I dont need the cor cause I want to do all the signaling by dsp but still hoocked it up in case…
So does this make sens? cause I cant have the ctcss level right.
I try to switch the ctcss and voice from left to right in case I had reverse the wiring.
put both channel as tone and voice to test. no go I cant send ctcss from the URI.
I know I can send it from the repeater itself… But I want to control when it is sent.
Thanks for taking the time to help me :wink:
Hi Pierre:
Try this:
TKR 850 URI
8 23
9 22
10 21
16 1
25 8
This is per my external MUX and how I have my 850 setup for dual mode (DV and FM).
Note, you will need to configure the usbradio.conf file appropriately to send the tone out on the RIGHT channel and the Audio out on the LEFT channel.
Let me know how it goes!
Ramesh.
On 16/11/2014 11:13 AM, pete M wrote:
Hi guys..
here is what I did:
12 to 19 (ground)
16 to 1 (ptt)
17 to 8 (cor)
still hoocked it up in case..
reverse the wiring.
the URI.
I know I can send it from the repeater itself.. But I want to control
when it is sent.
<-- don't forget the ground connection (see my drawing - how I connect audio ground and shields).
R.
On 16/11/2014 10:11 PM, Ramesh Dhami (VA3UV) wrote:
Hi Pierre:
Try this:
TKR 850 URI
8 23
9 22
10 21
16 1
25 8
Just to add to Ramesh's pinouts
TKR 850 -------- URI
8 (TD) --------- 23 (R_out)
9 (TA) --------- 22 (L_out)
10 (RD)-------- 21 (Mic in)
16 (EPTT)-------1 (PTT)
17 (SC) --------- 8 (Cor in)
12 (RXG) ------19 (Gnd)
19 (TXG) ------ 20 (Gnd)
You may need to add the extra audio grounds RXG and TXG.
Jon VA3RQ
On 11/16/2014 10:11 PM, Ramesh Dhami (VA3UV) wrote:
Hi Pierre:
Try this:
TKR 850 URI
8 23
9 22
10 21
16 1
25 8
Ramesh.
Hi guys..
here is what I did:
12 to 19 (ground)
16 to 1 (ptt)
17 to 8 (cor)
reverse the wiring.
the URI.
when it is sent.
I use a large 9 conductor shielded cable 16# wire that I is used in acces control system. got a 1000 feet roll doing nothing. I connect the shield on one side only, and I use one of the conductor for ground both the audio and signaling will switch that to 2 different cable.
so aside the obvious typo about pin 26 :wink: wich is 23… I was in the ball park…
Thanks both Ramesh and Jon for the info!
Date: Tue, 18 Nov 2014 08:49:33 -0500
CC: app_rpt-users@ohnosec.org
Subject: Re: [App_rpt-users] good connection to URI?
Just to add to Ramesh’s pinouts
Jon VA3RQ
Hi Pierre:
Try this:
TKR 850 URI
8 23
9 22
10 21
16 1
25 8
(DV and FM).
LEFT channel.
Ramesh.
Hi guys…
here is what I did:
9 to 23 (voice to tkr)
12 to 19 (ground)
16 to 1 (ptt)
17 to 8 (cor)
reverse the wiring.
the URI.
when it is sent.
the “Unsubscribe or edit options button”
confirmation. If you have trouble unsubscribing, please send a
message to the list detailing the problem.
confirmation. If you have trouble unsubscribing, please send a message
