Gm300 have to set the rxondelay very high
If I use software PL/CSQ decoding, I was getting reports of something coming back from the node after they unkey.
Turning RXondelay up to about 6 (6 increments of 25ms) it worked great until I tuned to the bottom of the 2-meter band and I had to turn it all the way to 15 to avoid problems. It’s fine unless someone quick Keyes and then I will loose the beginning of their voice.
This is a simplex GM300 node, so I am guessing there is a lack of high frequency noise immediately after I unkey. What I don’t get is why it is worse at the bottom end of the VHF band. I guess the VFO is sick down there and takes longer to activate?
On my UHF GM300, I can get away with rxondelay set to 5 at 446.000. I haven’t tested lower, but I won’t be transmitting below 445.0
There is a variable inductor that I found near the receiver chip which actually improved tuning it from what I was initially getting, needing to set rxondelay all the way up to 25. (It’s near the squelch pot)
I am going to use COR from the radio anyway so I won’t have the problem, but I was planning on modding one for 9600 baud which could never deal with the horrible TX/RX switching time that I am getting.
Any experience with this issue here? Also, It’s annoying that I have to run rxondelay, I wish it could just ignore the receiver immediately after the transmitter drops, no other time. Is there any other setting?
Skyler KD0WHB
Skyler Fennell
amsatnet.info
KDØWHB
electricity440@gmail.com
I have never had this issue and I run mine on DSP. Discriminator on rx and flat tx audio.
Corey N3FE
Skyler KD0WHB
Skyler Fennell
amsatnet.info
KDØWHB
Huh. I am running discriminator and flat TX. Did you ever test it simplex or was it only full duplex with two separate radios?
Skyler KD0WHB
Skyler Fennell
amsatnet.info
KDØWHB
Many ways actually. I have used it simplex like this and I have used it as a remote base using link2link, and at one point in time I was even using the steering lines and using it as a remote base. I have done this on both VHF and UHF.
Corey N3FE
Corey N3FE
Skyler Fennell
amsatnet.info
KDØWHB
Skyler KD0WHB
Skyler Fennell
amsatnet.info
KDØWHB
I’ll post my usbradio.conf when I get home in 30 minutes. Do you mind sharing yours for a simplex gm300 node using DSP if you happen to have it?
Corey N3FE
Skyler Fennell
amsatnet.info
KDØWHB
Skyler KD0WHB
Skyler Fennell
amsatnet.info
KDØWHB
Here is my usbradio.conf file :
[general]
[usbVHF]
hdwtype=0
rxboost=0
txboost=1
rxctcssrelax=1
;txctcssdefault=250.3
;rxctcssfreqs=100
;txctcssfreqs=100
;USE THE FOLLOWING FOR THE GM300 RADIO TO DO CSQ/PL DECODING
;rxctcssoverride=0 ;DO NOT SET THIS TO 1, I wired it up weird so COR means CTCSS
;carrierfrom=usb
;ctcssfrom=usb
USE THE FOLLOWING FOR THE SOFTWARE TO DO CSQ/PL DECODING
rxctcssoverride=1 ;CSQ MODE, Reccomended for remote base configuration!!!
carrierfrom=dsp
ctcssfrom=dsp
rxdemod=flat
txprelim=yes
txlimonly=yes
txtoctype=phase
txmixa=composite
txmixb=no
invertptt=0
duplex=0
rxondelay=13
;rxsquelchdelay=0
rxnoisefiltype=0
eeprom=0
Corey N3FE
Skyler Fennell
amsatnet.info
KDØWHB
Corey N3FE
Skyler Fennell
amsatnet.info
KDØWHB
Skyler KD0WHB
Skyler Fennell
amsatnet.info
KDØWHB
Skyler Fennell
amsatnet.info
KDØWHB
